SOHC.co.uk Forums > CB750
Choke knob k8 USA won't stay out
<< < (3/3)
Simon46:
I don't want a pattern peg.need the American Walmart one.!
Seriously I found I have to remove the grommet rotate my knob120 degrees anticlockwise holding the base of the plastic housing. Am going to tighten my nut as it appears to be spinning. Only rotates on full choke nothing in between
BigAl (Alan):
I 'think' the choke set-up is similar to my 1980 XL500s (as image)
Once the grommet is pushed up, the plastic nut below is turned slightly (there are plastic collets within the nut that grip the choke shaft) If there is no resistance on this nut its possible the plastic collets have broken.
Trigger:
Fitted to many honda's from the late 70's and 80's. The USA ones are nearly always cracked, try looking for one off a UK CM, CX and so on.
Simon46:
Thanks trig will look for this. Its like the bike has been baked in a barn.
Ps big Al your loom is still supplying many amps and volts to my batt!
BigAl (Alan):
Thanks Simon, glad the loom worked out.  Good luck with your search for a choke cable assembly...or peg!
Navigation
[0] Message Index
[*] Previous page
Go to full version
