Author Topic: Clutch  (Read 3956 times)
Offline hondatri
Clutch
« on: September 04, 2018, 04:11:18 PM »
 Hi The old Fart is Having a Senior Moment. Is there a push rod going through Hole through lock nut. I dont see one in Parts listing.
Re: Clutch
« Reply #1 on: September 04, 2018, 04:23:24 PM »
Is it number 130 you mean? This is an adjuster bolt but not a push rod.
« Last Edit: September 04, 2018, 04:34:54 PM by Nurse Julie »
Offline hondatri
Re: Clutch
« Reply #2 on: September 04, 2018, 07:35:43 PM »
No  Iam just wondering if there is a push rod to operate clutch  ( I am used to older bikes not familiar with the 400) I am just thinking that their should be a rod there before I fit springs and Plate. When I fit the new plates and tighten up and lock the castellated  is there a push rod or does anything go through the hole.
Re: Clutch
« Reply #3 on: September 04, 2018, 08:10:20 PM »
No, the CB400/4 doesn't have a push rod. The CB500/4 has a full length push rod and the CB550 a very short stubby push rod.
Offline hondatri
Re: Clutch
« Reply #4 on: September 05, 2018, 05:13:46 PM »
Thanks for pointing me in right direction.Much appreciated
Offline hondatri
Re: Clutch
« Reply #5 on: September 15, 2018, 02:41:23 PM »
Clutch Sorted Thanks guys for Info
