SOHC.co.uk Forums > CB350/400
Indicator relay
Chris whit:
Thanks Bryanj , cant see any rivet on the boss , is the rivet on the front face of the lock above we’re the key goes in , by the way it is a Neiman type lock . Should there also be a cover plate that covers the front of the key face similar to the seat lock . Ill take a photo but not sure how to add one on this forum .
Bryanj:
Yes the rivet should be on the boss, no cover plate just a circular washer to stop the lock comming out
Chris whit:
That’s what’s confusing me , there is no rivet so it looks like the previous owner has tried to remove it and there is no head showing then powder coated the frame thus covering the remaining rivet . Any chance of a photo of how it should look with the rivet in tack . Looks like I’ll have to drill the rivet out .
Nurse Julie:
Chris whit:
Thanks Julie, that’s great . Just as I thought the previous owner had already removed the rivet head and washer then painted over the remaining . I’ll clear of the paint then drill the rivet and lock .
Thanks for your help 👍
Navigation
[0] Message Index
[*] Previous page
Go to full version
