Author Topic: Engine paint what primer??  (Read 5142 times)
Offline Wenman
  • First build done cb550 supersport
« on: September 23, 2018, 07:40:55 PM »
Can anyone recommend any engine paint please?
Obv thinking a high temp VHT preferably a satin black?
Also I was going to use an acid etch primer due to the aluminium?
Will any acid etch work? Does it come in a high temp version?
Thanks u lot!
Al
If at first you don't succeed.. hit it with something!
Re: Engine paint what primer??
« Reply #1 on: September 23, 2018, 07:46:12 PM »
Simoniz VHT, no primer or etch required. If you wanted silver I would suggest SIMVHT31D but I don't know the part number of black off the top of my head.
Edit...SIMVHT20C is black.
« Last Edit: September 23, 2018, 07:50:06 PM by Nurse Julie »
Offline Wenman
« Reply #2 on: September 23, 2018, 08:01:03 PM »
Thanks Julie!
Would anyone know if have cleaned and sandblasted the head and barrels, if I wanted to leave it unpainted would I have to coat it with anything to prevent oxidisation etc?
Al
« Reply #3 on: September 23, 2018, 08:08:01 PM »
It will oxidize quite quickly if left bare, it would need something i'm sure unless you want to de fluff it every weekend 😭😭
Offline UK Pete
« Reply #4 on: September 24, 2018, 08:13:43 AM »
Heat proof clear coat
Offline Piki
« Reply #5 on: September 24, 2018, 08:53:45 AM »
I have my engine with a sandblasted work(about 5 or 6 years ago) and not paint or protection, and looks as the first day, not oxidation, is true that I live in Spain and the weather is different......
« Reply #6 on: September 24, 2018, 09:17:52 AM »
It does rain in Spain though. Doesn’t it ?
« Reply #7 on: September 24, 2018, 10:55:51 AM »
Mainly on the plains ;) ;)
Offline gtmdriver
« Reply #8 on: September 24, 2018, 12:14:43 PM »
I used POR15 engine enamel on my Moto Guzzi engine after cleaning it and preparing it with POR15 Metal Ready/Prep.
It stayed on when petrol and even battery acid got spilled on it.
Offline Piki
« Reply #9 on: September 24, 2018, 12:55:18 PM »
I live in Madrid and here doesnt rain much (20 days to the year perhaps...).....I think that  salt on the roads is the problem, but here there is not that problem (at the north of Spain yes) or near of the coast zone, not problem about oxidation here, belive me.
« Reply #10 on: September 29, 2018, 08:09:14 PM »
I'm hoping that climate change will bring your weather up to us soon! 😎
Offline Green1
« Reply #11 on: September 29, 2018, 09:33:14 PM »
I wish my Guzzi engine looked that good. Mine looks like its been dunked in the ocean and it only has around 9000 on it.
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
« Reply #12 on: September 30, 2018, 01:39:18 PM »
In 2007ish I just cleaned the engine with paraffin to degrease it and then got rid of the oxidation with my Dremel/Brillo pads/bits and bobs, no primer, then painted it using US Automotive VHT Aluminium paint, the head, barrels, etc that were separate were baked in the oven. It's lasted well but needs a bit of work now.
« Reply #13 on: September 30, 2018, 02:35:12 PM »
They always say you can polish a turd,
 but it's still a turd!
Offline petermigreen
« Reply #14 on: September 30, 2018, 06:29:12 PM »
I did my 500 head and barrels and baked in the oven. But I managed to support them in the oven in such a way that the liners slid out of the barrels  :o
I had to turn them around and put them back in till they got hot enough and slid back in. DOH!
Paint came out okay though.
Peter
