CB350/400
Link size help
Topic: Link size help (Read 2797 times)
Davelu88
Link size help
October 14, 2018, 06:11:26 PM »
HI all . need to get a new link for my 400 chain but am unsure what size to order the chain has 96 links without split link . many thanks
hairygit
Re: Link size help
October 14, 2018, 06:24:21 PM »
If it's running a standard size chain it should be a 530 (in old money 5/8ths X 3/8ths)
Davelu88
Re: Link size help
October 14, 2018, 06:27:38 PM »
Many thanks for that
Re: Link size help
October 14, 2018, 07:12:31 PM »
Pproblem you have is whilst width and pitch are a "standard" different manufactureres can use different pin and bush sizes so you need the same make as the chain to be safe
Davelu88
Re: Link size help
October 14, 2018, 08:26:25 PM »
I Dont know make of chain, which is a pain
Re: Link size help
October 15, 2018, 03:07:15 AM »
There is usually some sort of mark on the side plate of the link from which you can determine the make. Did you fit it so you know where it came from?
Davelu88
Re: Link size help
October 15, 2018, 01:49:34 PM »
No it came with the bike but has clearly very little miles on it but it had a rivet link so when the engine came out and a rear wheel refurb i ground off the rivet link . It does say EK50 HVO on the links but i cant find any info on this chain
Last Edit: October 15, 2018, 01:59:10 PM by Davelu88
Nurse Julie
Re: Link size help
October 15, 2018, 02:25:36 PM »
http://setiawanteknik.com/wp-content/uploads/2016/06/EK-Roller-Chain.pdf
Davelu88
Re: Link size help
October 15, 2018, 02:40:20 PM »
Trust a Nurse to help !! Thanks Julie
CB350/400
Link size help
