Author Topic: CB400/4 rear hub bearing retainer  (Read 3315 times)
« on: October 16, 2018, 03:25:35 PM »
I have a spare rear hub here that I'm going to refurb but which way does the bearing retainer undo?. I have looked in Haynes and the Shop Manual but it makes no mention. Does this lack of mention mean it undoes the normal way, or is it a back to front thread, so......left or right to undo?
Re: CB400/4 rear hub bearing retainer
« Reply #1 on: October 16, 2018, 03:32:57 PM »
It's normal RH thread Julie ..the only LH thread I have found on a Honda  was on the 500/4 and it's steel on that one.
I removed a couple of 400/4 retainers last week ... I made the mistake of not drilling out the staking indents enough on the 1st .. second was dead easy once drilled deep enough.
« Last Edit: October 16, 2018, 03:35:44 PM by AshimotoK0 »
« Reply #2 on: October 16, 2018, 03:37:21 PM »
Thanks Ash. I can now start whacking the removal tool in the right direction  ;D
« Reply #3 on: October 16, 2018, 03:52:02 PM »
You and Graham not talking  ;D ;D ;)
« Reply #4 on: October 16, 2018, 05:06:18 PM »
No Paul, Incommunicado as they say. He is in mass engine stripping / prepping /building mode and I am in rear hub mode. From a conversational point of view they are totally incompatible, I am wanting to talk huge hammers and he is mumbling on about so many 'thou of a 'thou, so, on my own with this one  ;D ;D ;D
« Reply #5 on: October 16, 2018, 05:10:01 PM »
Go back and mutter microns at him julie, might be worth googling it first!
« Reply #6 on: October 16, 2018, 05:21:48 PM »
Bryan, if i mentioned Microns, Graham would think i'm talking about Mucron for sinus congestion  ;D ;D ;D
Offline Rozabikes Tim
« Reply #7 on: October 16, 2018, 06:05:40 PM »
Nice noisy spannies though.
« Reply #8 on: October 16, 2018, 08:44:55 PM »
The nut on the fuel tap?🤔
Offline robvangulik
  • Honda Fourever
« Reply #9 on: October 16, 2018, 10:00:49 PM »
Thanks Ash. I can now start whacking the removal tool in the right left direction  ;D
;D
