Author Topic: Carburettor Insulators  (Read 17532 times)
Re: Carburettor Insulators
« Reply #15 on: October 25, 2018, 10:52:22 AM »
Opp's my last post contained a Senior moment..... If you take the petrol tank off you should be able to see the tops of all the insulators and there all the numbers..... Simples  ::)
Offline Deano400
« Reply #16 on: October 25, 2018, 10:55:30 AM »
Have now found the numbering after reading Laverda120's post. Would still like to know what the divots are for though on two of them.
Davelu88
« Reply #17 on: October 25, 2018, 11:04:45 AM »
Just looked at mine and apart from the 1 and 4 cut away which I guess as others have said is for grip I can't see any difference
« Reply #18 on: October 25, 2018, 11:24:50 AM »
The divots are where the golf club missed
« Reply #19 on: October 25, 2018, 02:33:38 PM »
Ok, I have had a proper look and rummage now. The flat sides face each other on carbs 2 and 3. When everything is in place, the big fat breather pipe from the top of the engine goes down between carbs 2 and 3 and through to the air box assembly. Without these two flat spots, the pipe would be very, very to get through, almost impossible by the looks of it, so this design stops the pipe from getting crimped.
« Reply #20 on: October 25, 2018, 03:24:57 PM »
Julie, that's a good theory, but the engine breather hose goes over the top of the carbs, in the frame clip under the frame tube alongside the wiring harness, down behind the plastic air box and joins the contraption under the air filter.
The routing is shown on p87 of the dealer manual. I guess this keeps the rubber hose away from the engine heat as much as possible.
« Reply #21 on: October 25, 2018, 03:45:26 PM »
Do you know something, that's bloody amazing and yes, I can see it on page 87. My old 400/4 and this one has it routed between the carbs, I will have to re route it but the angle at the bottom before it goes into the air box bit, would be so acute, I would worry it would clamp itself off.
Edit...does anyone know if the original factory fitted breather pipe had bends shaped in to it?
« Last Edit: October 25, 2018, 03:50:41 PM by Nurse Julie »
« Reply #22 on: October 25, 2018, 03:51:45 PM »
See attached  ;)
« Reply #23 on: October 25, 2018, 04:09:04 PM »
See attached  ;)
That's what I have been looking at Paul in my manual, what route does yours take?
« Reply #24 on: October 25, 2018, 04:20:27 PM »
See attached  ;)
The one above in the manual  :)
« Reply #25 on: October 25, 2018, 04:28:42 PM »
See attached  ;)
Ok, I will re route mine then, I don't like being too different to everyone else 😂😂😂 But, it also F's my theory of why they have flat spots on No's 2 and 3. I don't think it can be just for ease of handling, it just doesn't make sense to me.
« Reply #26 on: October 25, 2018, 04:36:01 PM »
Julie, I thought that it would be a tight bend at the bottom as well but it's not too bad. I made the mistake of fitting the breather hose after assembling nearly everything else. Getting hands in there to fit it to the plastic gizmo is a nightmare!
I thought I would have to remove a few items to make space, but I did manage it eventually, with a few skinned knuckles. The chainguard was off which helped. 🔧👍
« Reply #27 on: October 25, 2018, 04:44:09 PM »
Luckily, I have very small hands, just right for getting in awkward places  ;D ;D My 400/4 is off the road now for the winter so i will add that to the fettle list.
« Reply #28 on: October 25, 2018, 04:55:04 PM »
They are 2 types. One is marked 1 and 4, the other marked 2 and 3. It depends which side you're looking at.
« Reply #29 on: October 25, 2018, 04:59:18 PM »
So are you saying that they have both numbers on and you just turn them round to show the correct number? eg 1 and 4 are on both sides of the outer insulator
Yep. Took me ages to notice it!
