SOHC.co.uk Forums > CB350/400
oil filter cover bolt
<< < (2/2)
SteveD CB500K0:
Yes.
Get a 17mm head one. Makes life easier.
Just don’t torque it up too tight.
Bryanj:
There should also be a spring on the outside of the bolt to push the filter towards the engine and a thin steel washer between the spring and filter, frequently sticks to the rubber seal on the filter and gets thrown out with the oil
ricardo:
Many thanks for the advice. Should I re fit the ugly oil cooler or just ride in a leisurely fashion?
Ricardo
Bryanj:
Only need the cooler if being an utter looney in a hot summer. Just change the oil and filter regularly 1500miles/annualy
ricardo:
Dear BryanJ
That is the correct answer thank you.
Ricardo
Navigation
[0] Message Index
[*] Previous page
Go to full version
