Author Topic: Clocks and front brake calipers of CB400f2...gloss or satin?  (Read 3008 times)
Offline Athame57
« on: November 06, 2018, 09:53:34 AM »
I'm going to paint the clocks and the front brake calipers of my CB400F2...it's clear someone has done this before and not too well. They are gloss just now but I suspect it should be satin?
1978 CB400F2 named Elen.
Re: Clocks and front brake calipers of CB400f2...gloss or satin?
« Reply #1 on: November 06, 2018, 10:24:22 AM »
Yep, both should be satin black, PJI make a good black satin but it requires curing at 100c, OK for the brake caliper but I wouldn't use it on the clocks unless you have stripped them down.
« Reply #2 on: November 06, 2018, 11:00:55 AM »
Satin
« Reply #3 on: November 06, 2018, 12:45:58 PM »
Satin
Offline SumpMagnet
« Reply #4 on: November 06, 2018, 03:19:04 PM »
I got to do the ones on my 750, and I am going satin. I will 'cure' it in the oven as I will be taking out the pistons and fitting new seals as a matter of course.
CB750F2 - in pieces
Offline Athame57
« Reply #5 on: November 06, 2018, 03:26:45 PM »
Is it ok to use normal paint on the caliper?
« Reply #6 on: November 06, 2018, 03:38:13 PM »
Offline Athame57
« Reply #7 on: November 06, 2018, 03:52:09 PM »
 ;D Will get some!
Offline SumpMagnet
« Reply #8 on: November 06, 2018, 08:32:38 PM »
That's the stuff I bought...the VHT stuff.
I wouldn;t use ordinary sporay paint as I have seen what brake fluid does to it....and this stuff says it's chemical resistant.
CB750F2 - in pieces
