Author Topic: Breather Tube 400F  (Read 6150 times)
Davelu88
Breather Tube 400F
« on: November 25, 2018, 09:26:53 PM »
Hi all
     Does anyone know where i can get the breather tube that goes from top of breather cover to the chamber under air box part number  950051147030 or an alternative.
Re: Breather Tube 400F
« Reply #1 on: November 25, 2018, 10:56:34 PM »
I don't think they have been available for a long time Dave. Graham has found me some pipe to replace mine with, I will email you tomorrow and let you know where Graham got it from.
Davelu88
« Reply #2 on: November 25, 2018, 11:37:41 PM »
Thx Julie, you can always trust a nurse  :)
Offline Athame57
« Reply #3 on: November 26, 2018, 03:48:16 AM »
1978 CB400F2 named Elen.
« Reply #4 on: November 26, 2018, 08:08:50 AM »
£9 plus delivery for a piece of rubber hose he probably gets of eBay for 50p
Robbing james hunt  >:( >:(
Offline Deano400
« Reply #5 on: November 26, 2018, 09:04:25 AM »
Hi Julie,
Can you let me know also. I need two, one for my bike and one for my brother's.
John
« Reply #6 on: November 26, 2018, 09:15:33 AM »
Hi Julie,
John
No probs John, I will email you later.
Offline Seabeowner
« Reply #7 on: November 26, 2018, 10:28:38 AM »
I bought all my hose from:
https://www.advancedfluidsolutions.co.uk/
I think they list on ebay also.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Davelu88
« Reply #8 on: November 26, 2018, 11:11:13 AM »
Thanks for replies ,i got one from Julie's link at half the price of DSS plus free P&P !!!!!
« Reply #9 on: November 26, 2018, 11:17:00 AM »
When I get back to my PC I will post the link here for others that may be interested.
« Reply #10 on: November 26, 2018, 12:05:42 PM »
Here is the link.....it is 11mm ID x 16.5mm OD
There are obviously other companies that do it but, this is about the cheapest at the moment.
https://www.ebay.co.uk/itm/Nitrile-Rubber-Smooth-Fuel-Tube-Petrol-Diesel-Oil-Line-Hose-Pipe-Tubing-Breather/130740225601?hash=item1e70b98641:m:mqsrQWhQflcsGakZ6c38ECg:rk:1:pf:0
« Last Edit: November 26, 2018, 12:07:16 PM by Nurse Julie »
Offline Seabeowner
« Reply #11 on: November 26, 2018, 12:31:53 PM »
Yes, that's Advanced Fluid Solutions ebay tag. I found sometimes it was cheaper through ebay and sometimes direct. Depended on quantity.
« Reply #12 on: November 26, 2018, 01:51:26 PM »
I use them Julie and it's always been spot on.
Offline mattsz
« Reply #13 on: November 26, 2018, 05:05:43 PM »
Is it just the photo, or is that tubing really as flat as it looks?  Does it pinch closed if you bend it around the airbox along its intended routing?
« Reply #14 on: November 26, 2018, 05:33:11 PM »
That's just a trick of the light, if you look at the open end of the tubes, they are round.
