Author Topic: Car type oil filter on 400/4 ???  (Read 6136 times)
Re: Car type oil filter on 400/4 ???
« Reply #15 on: March 30, 2019, 04:56:09 PM »
« Last Edit: March 30, 2019, 05:01:13 PM by AshimotoK0 »
« Reply #16 on: March 31, 2019, 07:32:18 PM »
Here are the pics of the blocked off port.
« Reply #17 on: March 31, 2019, 07:56:20 PM »
I could be talking out of my backside here but, I'm sure that only 1 hole is patent on my CB400/4. I'm trying to find a good pic in my photos to show it but can't find one.
« Reply #18 on: March 31, 2019, 08:06:00 PM »
Yes, one hole is plugged as standard as photo. Just looked at a CB500/4 one as well and that only has only one hole patent also
« Reply #19 on: March 31, 2019, 08:06:38 PM »
I'm not familiar enough with the 400 engine to say that it's normal just from that picture,  you need another to compare as Julie says.
But my read of it is that it's the manufacturing process that needs to go through there to connect an internal gallery to the filter output route into the engine.
Looks like they've machined then plugged it to get in there that way.
If left open,  it would just allow the oil to bypass the filter route on it way to the internal galleries.
« Reply #20 on: March 31, 2019, 08:09:06 PM »
I crossed over there with you Julie,  that external gallery with bolted cap is I presume feed from oil pump into filter chamber.
« Reply #21 on: March 31, 2019, 08:10:38 PM »
Just what i was going to say Nigel 👍👍👍
« Reply #22 on: March 31, 2019, 08:52:17 PM »
Thanks everyone ... I also checked my 500K0 crankcase earlier tody  and it has a similar blacking plug ... so I guess I can put his mind at rest.
