Author Topic: 1976 CB550F1 (what have I let myself in for) Project  (Read 149646 times)
Offline eight0
Re: 1976 CB550F1 (what have I let myself in for) Project
« Reply #210 on: February 26, 2021, 04:15:06 PM »
I really hope so. I put them back on the same way they were on. Letters facing forward, numbers backwards.
You can just make it out in this photo.
« Last Edit: February 26, 2021, 04:17:13 PM by eight0 »
« Reply #211 on: February 26, 2021, 04:34:01 PM »
Conrods should be installed with 'bearing key' facing forward - 'bearing key' is the bearing locating notches
Offline eight0
« Reply #212 on: February 26, 2021, 04:54:06 PM »
I can't say for certain then. I put them on how they were but as I bought the replacement crank from DK maybe they had removed them and put them back on the other way around.
Guess that means I'll have to split the cases again.
« Reply #213 on: February 26, 2021, 05:20:32 PM »
If they had been messed with prior to you getting them, the people who messed with them would have had to have put all 4 rods on 180 degrees wrong as you say the letters were all facing forward - ie, all 4 are either all facing right way or all 4 all facing wrong way.
I have just done my 500 (that is I have just fitted barrel) and can't remember whether letters were forward or back facing - only that the letters were all facing the same way.
I would suspect the piston/barrel tolerances and take piston off and insert pistom/rings into the barrel off the rod to check for tightness - that will isolate the source of the tightness. You can check tolerances at this stage either way
Offline eight0
« Reply #214 on: February 26, 2021, 05:30:27 PM »
Hang on. I've just found a photo from when i received the crank. I think I've messed up. This would be numbers forward wouldn't it?
It's been a long week.
Offline eight0
« Reply #215 on: February 26, 2021, 05:48:24 PM »
Thanks for the help so far everyone.
Yes it span smoothly without resistance. I'll check end gap tomorrow and post the results.
Offline eight0
« Reply #216 on: February 26, 2021, 05:49:32 PM »
The odd thing is the fact the outer pistons don't seem centered to the bores
Offline eight0
« Reply #217 on: February 26, 2021, 05:58:02 PM »
Yeah, seriously regretting it now.
They were piston kits from DS, including the rings, pin and circlips.
Offline eight0
« Reply #218 on: February 27, 2021, 03:55:16 PM »
The rings are marked R 25.
Just checked the ring gap and it's .30 on all cylinders
Offline eight0
« Reply #219 on: February 27, 2021, 06:55:55 PM »
Mm
« Reply #220 on: February 27, 2021, 07:40:14 PM »
Thats right Ken, i inherited a Van Norman and bought  an SPS. Both fit on the same table but cutters are different
Offline eight0
« Reply #221 on: February 27, 2021, 08:08:19 PM »
Ok I'll remove the pistons and see what they're like in the bores without the rings.
I'm at a loss for what to do here now to be honest.
Offline eight0
« Reply #222 on: February 28, 2021, 11:55:25 AM »
I've pulled the head again and checked the piston that was hanging up the most.
Without the rings it drops through. With the rings it's really tight, but maybe it's supposed to be this tight?
https://youtu.be/glUKwGO5nxU
« Reply #223 on: February 28, 2021, 12:18:38 PM »
No, that is definitely not right.
Edit... Difficult to see on the vid but there appears to be a big gap fore and aft, piston to barrel. Have you tried that piston in another bore?
« Last Edit: February 28, 2021, 12:21:50 PM by Nurse Julie »
Offline eight0
« Reply #224 on: February 28, 2021, 12:27:07 PM »
It looks like there's a gap because of the taper at the bottom of the barrel.
Good to know that shouldn't be like that I guess. I was contemplating cracking the cases again. If I have to get more pistons and another rebore then so be it. I'm this deep in.
