SOHC.co.uk Forums > CB750
Recommended Compression Gauge for cb750
Rob62:
Yeah that was just the first one i found on ebay...they do make one for bikes, i used one on my cb750 earlier this year. 8)
K2-K6:
Most of the bikes are 12mm, I think with very few exception on the four strokes.
Full description is 12mm metric fine, I believe, as it's 1.25mm thread pitch. Straight metric, again I believe, to be 1.5mm pitch which is normal engineering size for non specific use.
The need to be a little careful is there if you wish to avoid a mash-up.
I've no recommendation as my screw in type is an old Sykes-Pickavent which I can't find a current example of.
The one's with rigid tube and rubber cone that you just hold in the plug hole while you turn it over are a little awkward but they do work well and have always given me repeatable readings.
You can assess if they are giving realistic readings by trying them in another known good engine to see what they read.
philward:
Done a bit of research on the Gunson gauge that Rob recommended and you buy adaptors for the 12mm thread. I've no real use for it at the moment - just building my tool base for the future, although will use it on my next project as it will be my first 750 that won't have a full engine build as it was sold to be as a good runner (?????)
philward:
Just some info for anybody looking for good value kit - 15% of this price until 14th do paid £39 squid ish - thanks for guidance Rob
https://www.ebay.co.uk/itm/New-Gunson-Compression-Tester-Kit-6pc/160449707101?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Rob62:
Nice one Phil. It may not be the cheapest option but im sure you will get a lifetime of reliable service from it 8)
Navigation
[0] Message Index
[*] Previous page
Go to full version
