SOHC.co.uk Forums > CB750
I've bought UK Pete's Ruby Red K1
<< < (4/4)
Andrew-S:
Thanks for the heads-up, I'll look into that stuff.
Sgt.Pinback:
Lovely patina.
Andrew-S:
Bit of progress on the K1 today, spent 4 hours cleaning up some of the sharp end - tried a new product (to me) for cleaning and protecting chrome and plastics; 'Quick-Glo', pretty happy with the result after the first effort:
UK Pete:
Wow it works well
AshimotoK0:
--- Quote from: Jamesh_sussex on December 23, 2018, 12:28:53 PM ---Andrew - I use Bilt-hammer Deox-C to derust my tank internals. You Do need to flush out any gunk/varnish residue first. I normally remove the stale fuel, then degrease / flush (if you’re careful you can use a pressure washer lance to clean out internally. Then make up a Deox-c solution with hot water and fill the tank with the solution warm.
--- End quote ---
Been using that stuff for many years as we have a 40 litre heated bath of it where I work BUT .. don't leave any chromed parts in it for an extended period as I left a CB250K front guard in it and it started to strip the chrome under where the original pitting was. Having said that a quickish immersion of a USA 500/4 rear guard worked wonders on the underside.
Navigation
[0] Message Index
[*] Previous page
Go to full version
