Author Topic: Box section swing arm?  (Read 11460 times)
Offline Arch stanton
Re: Box section swing arm?
« Reply #30 on: December 29, 2018, 03:25:56 PM »
25mm of shoulder & 20mm of thread. = 45mm overall.
Hope this is of assistance.
Sean. If
Offline SamCR750
« Reply #31 on: December 29, 2018, 05:29:07 PM »
I thought it might be but wasn't 100% sure, it is the same as all the early Ks.
It's just the late Ks, F2 and Autos that have it longer on the drive chain side.
« Reply #32 on: December 29, 2018, 09:08:22 PM »
I wonder why that was?
Offline SamCR750
« Reply #33 on: December 29, 2018, 10:29:05 PM »
I can only guess Sean as I never measured it but I'm guessing the gearbox sprocket is about 5/8th of an inch further out on the shaft.
On all the later models, everything is cranked out on the near side.
I'll see if I can find a picture of the problems I had when I tried to fit a K swingarm into an Auto frame.
Offline SamCR750
« Reply #34 on: December 29, 2018, 11:02:48 PM »
Sean, look at the angle of the left rear strut, this is what happens when you mix early with later model parts.
Can you imagine IF you could get a shock to fit, the problems it would have going up and down.
« Reply #35 on: December 30, 2018, 08:53:53 AM »
Was there any particular reason for using a A frame!?
Offline SamCR750
« Reply #36 on: December 30, 2018, 07:30:25 PM »
It was all Automatic apart from the swingarm Sean.
