Author Topic: New Member  (Read 19715 times)
Re: New Member
« Reply #30 on: December 29, 2018, 10:25:55 AM »
Thanks matthewmosse for your advice. Sounds like a bit of a minefield out there! I think I need to be very careful about what I buy.
The problem that regularly occurs is if you 'think' about it too much or try and find the 'perfect bike' for you, the chances are you will never buy one. Then when you do buy one eventually, because you have such high expectations based on your research, you can be very disappointed. Sometimes you jyst have to throw caution to the wind and take a chance. Have you ever owned a classic bike before Bradders?
Offline Bradders
Re: New Member
« Reply #31 on: December 29, 2018, 10:43:49 AM »
Hi Julie. No never owned a Classic before, CJ250 when I was 17 and a Kawasaki 305 and Yamaha XJ 600 about 20 years ago.
Re: New Member
« Reply #32 on: December 29, 2018, 11:35:08 AM »
Bradders, I agree with Julie. Jump in whilst you can and have the enthusiasm.
The advantage you have at the moment is now its winter bikes are cheaper. If you leave until spring prices will only go up.
Offline matthewmosse
Re: New Member
« Reply #33 on: December 29, 2018, 02:43:18 PM »
Thing is most bikes are good because the quality was ace when built. Bear in mind I buy the cheapest old bangers out there and ran them as daily transport on a budget of pence. If your going out with a decent bank balance then your odds are you'll get a decent bike if you just go in with some basic idea of what might warn you of bad news. My most expensive bike ever was a BMW with a slight leak by the gearbox, turned out it was a warning the gearbox was toast, not the worst news ever, but for a commuter bike, spending an extra £500 replacing the clutch and gearbox with all new or recon bits.
Offline Green1
Re: New Member
« Reply #34 on: December 29, 2018, 05:07:34 PM »
Just do it.
Nothing wrong with a US import more or less the same as a UK equivalent to the untrained eye and a lot cheaper
You can't get simpler or more reliable then a classic Honda  ;)
Current bikes
Honda CB750k1 Candy Gold
Honda CB550k Candy Jade Green
Triumph tiger 800
Aprilia Pegaso 650
Moto guzzi 1200 sport
Kawasaki ZXR400 J
Offline Bradders
Re: New Member
« Reply #35 on: December 30, 2018, 11:38:52 AM »
Thanks to you all for the advice and encouragement. What a great forum you have, helpful and friendly.
Offline Phil Ward (RIP)
Re: New Member
« Reply #36 on: January 02, 2019, 08:56:58 PM »
Bradders, have yo seen this - Interesting to see what this goes for - UK model and good basis for resto
https://www.ebay.co.uk/itm/1980-Honda-400-4-CB400F2-V5C-Running-Bike-ideal-Light-Project-Ride-Or-Restore/352558801175?hash=item5216246117:g:y5IAAOSw-iZcLPm-:rk:23:pf:0
Re: New Member
« Reply #37 on: January 02, 2019, 09:52:58 PM »
Blimey, that's a late one, 1980 W.
Offline dave400
Re: New Member
« Reply #38 on: January 02, 2019, 10:12:38 PM »
Some 400’s got found in a wharehouse in Italy, my mates other half got a 400 new on a V plate it was the yellow version....nice. 8)
Offline Bradders
Re: New Member
« Reply #39 on: January 02, 2019, 10:25:10 PM »
Interesting. I was going to say I didn’t realise they were made that late. Looks very different to a normal 400/4. What would be the cause of the engine running problems?
Re: New Member
« Reply #40 on: January 02, 2019, 10:32:25 PM »
Blocked carbs due to old petrol residue - most bikes that have been standing for any length of time. Needs carb  strip and clean.
Sent from my Moto G (5) using Tapatalk
Re: New Member
« Reply #41 on: January 02, 2019, 10:33:06 PM »
1977 was when manufacture finished. Sounds like the carbs need sorting out for starters, he says the engine is quiet. Looks bloody horrible with that seat and those pipes. Will be interesting to see what it goes for though.
Re: New Member
« Reply #42 on: January 02, 2019, 10:36:49 PM »
Front end looks weird with that plastic mudguard and all the wrong headlamp / indicator assembly.
Re: New Member
« Reply #43 on: January 02, 2019, 10:38:31 PM »
I agree ref the looks and depends what it goes for as to whether it's worth buying - could be good basis for rebuild at right price - sell exhausts for decent money to fund standard parts
Re: New Member
« Reply #44 on: January 03, 2019, 12:48:08 PM »
Looks fairly solid, not too much corrosion to contend with... a few non std parts but overall a decent starting point  8)
