Author Topic: 500 ride again project  (Read 26945 times)
Re: 500 ride again project
« Reply #15 on: December 30, 2018, 09:30:33 AM »
The dog drive looks like it's been spitting back out from the look of the radius on those drive faces.
You need to compare them with a known good set to see how much they are worn. But they don't look disposed to staying in place under load. Don't think you could rely is on them even if everything else wash perfect.
If under load it's trying to separate the dogs it will heat up the selector fork as it'll be "leaning" on it which it's not supposed to do.
Is that back dog of the three sticking up a different size to the others? Can't get a good view of it in the photo, and is it supposed to be?
« Reply #16 on: December 30, 2018, 09:45:42 AM »
Pictures of Good centre, Right slight ware and a good left  ;)
Offline Safo
« Reply #17 on: December 30, 2018, 10:07:11 AM »
No Trigger it just felt like I wa pulling and releasing clutch very quickly
« Reply #18 on: December 30, 2018, 10:13:26 AM »
Sounds more like a clutch or push rod problem  ;)
Offline Safo
« Reply #19 on: December 30, 2018, 10:18:48 AM »
Would it do it only in 3rd and not in any other gear?
Offline Safo
« Reply #20 on: December 30, 2018, 10:42:28 AM »
I think k2 is on the right path, looking closer, there is a a lip on the fork, which suggests it's had some pressure from the gear, but contrary to the pic is not blue so hasn't had too much, it certainly isn't as good as the ones in the picture that trigger sent
Offline Safo
« Reply #21 on: December 30, 2018, 11:03:09 AM »
OK folks, reckon it's time  to accept that I've, (well the wife that is) cos it's her bike has to spend some big bucks and find some new bits, gonna see if silvers still got them repro gears I saw a few months ago
« Reply #22 on: December 30, 2018, 11:11:54 AM »
The only lip i can see is on the dog. Maybe some better pictures would be better  ;)
Offline Safo
« Reply #23 on: December 30, 2018, 12:03:14 PM »
Glad you asked for a better pic Trigger, this confirms what's been going on
« Reply #24 on: December 30, 2018, 01:12:26 PM »
I take it, that is the Right one ? Will have L & R on them  ;)
Offline Safo
« Reply #25 on: December 30, 2018, 04:49:00 PM »
Yes it says R2, but things just got worse, the middle one has suffered tne same, I also found the drum bolt in the top case wa loose the locking washer had bent back
« Reply #26 on: December 30, 2018, 05:10:18 PM »
You need to check what you need against a parts book. Anything with 323 middle number is 500 any other middle number is another model.
Offline Safo
« Reply #27 on: December 30, 2018, 05:35:21 PM »
Thankyou,will do, a mate of mine has a 450 twin bottom end, some say the k4 forks are same have I got a chance?
« Reply #28 on: December 30, 2018, 06:11:39 PM »
Not the same !
PN for the right is 24211-323-000 and PN for the centre is 24212-286-030, that relates to Honda Motorcycle Models with no year CB350 A GEARSHIFT + CHANGE PEDAL + SHIFT DRUM + SHIFT FORK
Honda Motorcycle Models with no year CL350 A GEARSHIFT + CHANGE PEDAL + SHIFT DRUM + SHIFT FORK
Honda Motorcycle Models with no year CB500K2 A Gearshift Fork / Drum
Honda Motorcycle Models with no year CB500K1 A Gearshift Fork / Drum
Honda Motorcycle Models with no year CB500 A Gearshift Fork / Drum
Honda Motorcycle Models with no year SL350 A SHIFT DRUM + SHIFT ARM
Honda Motorcycle Models with no year CB350G A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CB350K2 A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CB350K4 A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CL350K2 A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CL350K4 A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CL350K5 A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CB350K3 A Shift Drum / Shift Fork
Honda Motorcycle Models with no year CL350K3 A Shift Drum / Shift Fork
Offline Safo
« Reply #29 on: December 30, 2018, 07:13:45 PM »
Snookerd then, could be a long game,
Thanks all, will let you know when I find a way out
