Author Topic: Carb work  (Read 11689 times)
Offline mattsz
Re: Carb work
« Reply #15 on: February 13, 2019, 05:09:29 PM »
I've got a new o-ring set... it includes the rings for the pipes that connect the carbs together.  I wasn't planning on getting in that deep, as I mentioned earlier - just dismantle as much as possible without separating the bodies, then clean.  Do you guys think that's a false economy at this point?  I was told the bike was running great two years ago, but I really don't know.  If I'm going this far with the strip and clean, does it make sense to go the full monty?  Or is it wise to fix what I know is bad, then try it out?
Is there a specific resource which would show me specifically, on these carbs, what parts are what and where they go... the jets and float valve and such I know about, but what about the different passages?  I'm looking to dismantle the carbs enough to replace the rubber bits and clean everything as best I can, but without separating them, which means carb cleaning spray and compressed air.  And probably some degreaser for the exteriors...
Any thought on this?  Some tutorial or video?  Or do I just clean everything?
Re: Carb work
« Reply #16 on: February 13, 2019, 05:17:27 PM »
Personally I would not remove the back plate and split the carbs if I didn't think there was a problem that needed attention. I would pay more attention to the bits I can get to and make sure they are as clean as possible and fit new O rings etc. If you do need to remove carbs from the back plate and spit them, it is easy enough but it doesn't sound like it's necessary in your case.
Offline mattsz
Re: Carb work
« Reply #17 on: February 13, 2019, 05:45:39 PM »
Thanks Julie!  That's kind of where my head is at anyway, in case you hadn't sorted that out... but all the easy-access rings need replacing, so I was on the fence about digging further.  I will definitely check the balance of the slides on the bench; the choke linkages are mis-adjusted and I imagine the slides could be, too...
Offline blackeagles
Re: Carb work
« Reply #18 on: February 14, 2019, 12:04:07 PM »
I have both.  Interesting that the Honda service manual doesn't mention the needle grooves...
if you have the 'shop manual - honda cb350f-400f' (hwm002) by honda then its right at the back on page 95!
« Last Edit: February 14, 2019, 12:05:52 PM by blackeagles »
Offline blackeagles
Re: Carb work
« Reply #19 on: February 14, 2019, 12:13:59 PM »
easy maybe for some of you 'old timers' (not you julie of course :))) but i was finding it difficult just getting the slides out - 'cos i'm not used to honda multis' - but i see there are complete repair kits jets and all on ebay for about £30ish or with the floats for about £45ish which, if mine is still running so very rich after syncing them i may/will have to carry out - 4th time taking them off, but without trying them first you can not tell if they will work ok or not..
« Last Edit: February 14, 2019, 03:51:04 PM by blackeagles »
Offline mattsz
Re: Carb work
« Reply #20 on: February 14, 2019, 12:29:23 PM »
Yes, you're right, of course - I did notice that.  I wasn't clear, what I meant was, that I thought it interesting that that manual doesn't mention the grooves at all in the work description...
Re: Carb work
« Reply #21 on: February 14, 2019, 01:04:09 PM »
Keyster kits are not good for brass bits which rarely wear but usually have all the gaskets and O rings
Offline Dave487
Re: Carb work
« Reply #22 on: February 14, 2019, 09:01:52 PM »
I think you'll always get black sooty plugs if you're just checking them after idling as they don't hot enough to burn it off.
Re: Carb work
« Reply #23 on: February 14, 2019, 09:48:56 PM »
Also forgot to say 500's do run rich low down.
Offline mattsz
Re: Carb work
« Reply #24 on: February 18, 2019, 10:36:08 PM »
Someone gave me a carb jet cleaning tool.  Bikemaster says it's a necessity.  Is this useful, or should I avoid it like the plague?
https://bikemaster.com/carburetor-jet-cleaning-tool.html
Offline Moorey
Re: Carb work
« Reply #25 on: February 18, 2019, 10:51:33 PM »
Don't use it on your jets they will open them up as they are files used for cleaning Oxy cutting nozzles.
Re: Carb work
« Reply #26 on: February 18, 2019, 10:58:49 PM »
I have a set of those in Pink, purchased from Mr Silver many years ago. I use them on everything.....except carbs and never ever to clean out jets
Offline Athame57
Re: Carb work
« Reply #27 on: February 19, 2019, 03:58:09 AM »
Oh great,....now I find out! I don't think it's done any harm, but never again! :-\
1978 CB400F2 named Elen.
Offline ka-ja
  • ken
  • yoshi 460
Re: Carb work
« Reply #28 on: February 19, 2019, 08:54:37 AM »
Originally used to clean out gas welding torch heads, not for carbs.
nice bike,nothing in the bank
Offline mattsz
Re: Carb work
« Reply #29 on: February 19, 2019, 12:03:03 PM »
Huh.  So what, does Bikemaster sell new jets, too?  Handy business model!   :-X
