Author Topic: Bomber exhaust cams  (Read 13424 times)
Re: Bomber exhaust cams
« Reply #15 on: April 16, 2020, 05:58:31 PM »
They said the hardened part was easily thick enough to take a slight regrind.
Cheers Roy ... I doing a direct  exchange for a Bomber rear brake lever for the two sprockets & pins  to fix my cam chain ider assemblies with Franco Cappellini. I will ask him about the thickness of the hard welding.. he's bound to know.
http://www.cappellinimoto.it/catalog/motorbike/CB450K/product
« Reply #16 on: April 17, 2020, 08:54:09 PM »
I got this back from Franco Cappenneli regarding the exhaust cam.
I don't know the depth of the hardened part of the cams but I don't think it is remarkable, many cams, especially of exhaust I found ruined. I send the cams to the megacycle to modify them racing but it is a very expensive operation, they weld and re-profile the cams also with the original diagram. The rocker arms must be in perfect condition with whatever cam is used.
« Reply #17 on: April 17, 2020, 10:54:54 PM »
Big difference between a slight clean up grind to stock profile and a full profile change for racing. Also the revs will be higher on a racing engine.
« Reply #18 on: May 04, 2020, 10:31:31 PM »
Franco sent me a lovely condition  exhaust cam ... as a freebie couldn't believe it. So don't need Newman to do mine now.
« Reply #19 on: May 05, 2020, 08:44:19 AM »
Nice one Ash, that's a proper result.
« Reply #20 on: May 05, 2020, 05:48:14 PM »
Got beat to a good pair of fork seal holders on eBay. Did you get them Ash.
« Reply #21 on: May 07, 2020, 12:30:41 AM »
No mine are already rechromed Roy..  Jason bought them I think but they really needed rechroming anyway .......they were Mick Taylors (kettle738 on here)
