SOHC.co.uk Forums > CB750
Oil pipes tank to engine
<< < (3/3)
Moorey:
Is there no Dowty Seals that will fit. A common seal used in the hydraulic industry. https://www.ebay.co.uk/itm/Bonded-Seal-Washers-Dowty-Sealing-Washer-Hydraulic-Oil-Petrol-Sealing-Washers/132585478534?hash=item1edeb5d986:m:mPrtxEP2Ee3f-sLFUDzLwJw:rk:1:pf:1&frcectupt=true
philward:
Thanks for info - a member is going to include a set with his next bulk order
SteveCR7:
--- Quote from: Rob62 on January 30, 2019, 01:08:55 PM ---I  ended up changing both of mine to mend-a-hose specials... £35 each is a bargain and they look very neat, so long as your not looking for "best in show original restoration at the local VJMC rally"
--- End quote ---
I googled mend a hose and there is one not far from me so that looks like the no1 solution.  Already getting great advice on this forum.
Cheers Steve
Rob62:
They are suppliers to industry but they have a trade counter and my local outlet (Castleford) was happy to re-tube mine... did them while I waited... The stuff they use is stainless braided in metric size, not imperial like the original.. The guy mentioned that it was a little tight on the fitting but went on OK and crimped up fine, they couldn't offer their normal no-leaks warranty due to this, but as its not a pressure application there is no problem. The tube is about £85 / metre, total cost was about £35 each. I had mine done separately because one was leaking as soon as I put oil in the tank... a week later I noticed the other was also leaking but less noticeable.. Both have been perfectly dry since fitting and I think they look fantastic in braided stainless. If you get both of yours done at the same time you may get a better price than I did..?? Let us know how you get on.
SteveCR7:
I probably won’t be getting the pipes done immediately unless they are not serviceable to get the bike running but will post when I get them sorted.
Navigation
[0] Message Index
[*] Previous page
Go to full version
