Author Topic: shed/workshop  (Read 3276 times)
Offline haynes66
shed/workshop
« on: February 13, 2019, 06:50:49 PM »
i'm looking at building a much bigger timber framed workshop around 22' x 10' which will allow me to line up 4-5 bikes side by side.  the plan was to lay a concrete slab but it is super expensive, albeit permanent.  i am looking at concrete piers instead but not sure if the floor would be up to the job.  anyone done something similar?
honda firestorm
silverwing 600 scooter
honda britain project
phil read rep project
YGS1 80cc yamaha
LE Velocette
Offline matthewmosse
Re: shed/workshop
« Reply #1 on: February 13, 2019, 07:50:26 PM »
My 18x9 sheds just on a hardstanding - but well compacted by a 3/4 ton vibro roller,  with paving slabs, our woodshed is streight onto bedrock with just breezeblock pieces to keep the woodwork dry, it's fine, only downside is small things can drop into gaps in the pavers until the gaps fill with oil and dust, added bonus is any spills leak through the gaps rather than puddle up. Something heavier than motorbikes might make paver crack eventually but mine have stood up to Howard gem rotovators with steel spade lug wheels and those make your average motorbikes footprints appear delicate in comparison. Even withstanding my dexion racking that's groaning under the weight of spare hydraulic gear. Not bad for reclaimed 2" thick pavers. Cost wise I paid about £3 per 2'x2' paver for some new ones - end of line stock, then got more at £1 each reclaimed ones from a driveway company clearing out after a job. Makes for a cheap shed floor.
Offline haynes66
Re: shed/workshop
« Reply #2 on: February 14, 2019, 04:22:36 PM »
thanks. that's answered my question. i'm thinking of several piers under the entire floor.  the floor timber is 5" x 2" covered in 19 or 25mm ply which should be strong enough for load bearing.
honda firestorm
YGS1 80cc yamaha
LE Velocette
Re: shed/workshop
« Reply #3 on: February 14, 2019, 05:41:35 PM »
If you've much span between piers for the 5inch joists then it won't take much to bend them.
7inch is generally ok for decent floor support.  Unless you're going to have more piers to prevent centre sagging.
The ply seems OK,  we used 19 or 25 on batterns to support some fairly hefty machine on false floor in a factory.
Re: shed/workshop
« Reply #4 on: February 14, 2019, 06:38:57 PM »
I think our kitchen has piers at roughly a meter centres with 6x2 timbers - might actually be a grid of 4x2 thinking about it.... so total void 8" deep, bottom skin of weatherproof MDF and oak planks over the top, plus insulation layer in the middle, that has stood up to 8 years wear so far, with all the abuses of z working farm kitchen and 2 young boys can throw at it.
Offline flatfour
Re: shed/workshop
« Reply #5 on: February 15, 2019, 09:03:14 AM »
I bought and had built on site a cedar garage for the bikes when we moved here some seven years ago and it has been very good for the bikes (3) that normally live there and as a workshop. It is 20' by 10' and the floor is 19mm board that is claimed to be able to support a car (it is sold as a garage, after all). I did, however have a second sheet of the same flooring laid over the area that the bikes stand in (the far end of the building is used as a workshop, the entrance has the bikes stood side by side) as the floor would "flex" a little when the bikes were wheeled in. The supplier made the point that although the floor was rated at three tons, with the weight of a large tourer and the two older bikes being through the two main stand legs and front tyre, it was probably exceeding the design limit in those areas! We have, during holidays sometimes put a second car in there without any ill effects.
The base is brick weave, as is the rest of the drive and that has so far been satisfactory.
Offline Moorey
Re: shed/workshop
« Reply #6 on: February 15, 2019, 09:39:23 AM »
I got a mixer and bought bags of ballast and cement and mixed my own. It doesn't have to be done as one single slab. Do it in metre strips or what you would be comfortable with  to make it more manageable. It worked out far cheaper and better than timber and ply sheets,  Its not a lot of concrete you would only need approx 2 cubic metres. Timber and sheets are costly.
If there are any building works going on near you have a word with a mixer driver they often have "surplus concrete" at cheap prices the only problem been you have to be ready to deal with it immediately when they ring you to say they have a load.
« Last Edit: February 15, 2019, 09:41:01 AM by moorey »
Offline haynes66
Re: shed/workshop
« Reply #7 on: February 15, 2019, 12:46:54 PM »
moorey, that also makes sense as i dont mind a bit of hard work. a metre at a time would be easy enough.  the problem with readymix is that the back of the house is only accessible by barrow/bike so not really an option.
honda firestorm
YGS1 80cc yamaha
LE Velocette
Offline Moorey
Re: shed/workshop
« Reply #8 on: February 15, 2019, 01:32:07 PM »
It does take longer than you imagine to mix, depending obviously on mixer size. I just set my shuttering up so at any polnt I had had enough I could put a board across and finish the slab at that point with a couple more barrows full. The next day just remove the same board and work to that concrete edge. If you are on your own you might find a cube a day a bit much.
Re: shed/workshop
« Reply #9 on: February 15, 2019, 01:48:39 PM »
Going back about 18 years I did my workshop floor by normal belle mini mix cement mixers. Its 4 x4 metres roughly, an odd shape building that was a lean to on a barn. I laid it in sections. Doing a cb550 engine rebuild on an old dresser in 1 side one day, laying concrete next to it the next day. I found having two mini mixers a great boost to the speed of mixing concrete, you could load one up while the other was stirring its mix. A bit spoilt to have two mixers, one was from a neighbours skip, engine seized. Got it running, found it was still a pig to start - cracked valve guide, so whacked an electric motor on there. Think it took 2 days to lay the floor. Had a few details to accommodate, like a oak post buried into the floor, not concreted in for my anvil. And a steel girder that was very firmly connected to a decent depth to hold a leg voice. Think it was about £300 for cement, ballast and sand. It's way more heavy duty than a bike shed needs.
