Author Topic: Broken bolts in cylinder head....help!!  (Read 16000 times)
[JP]
« on: October 26, 2005, 09:02:57 AM »
well....not happy today..while putting the engine back together I broke 2 bolts in the cilinder head....
I was doing it with the torque wrench but without noticing it while I was doing the bolts my hand was turning the thing at the end of the torque wrench, increasing the torque.
So...when I notice it was 2 late..the bolts snapped....what do to now?
Can it be repaired'
do I have to buy that whole part new?
or can I throw everything in the bin?
As you can see it?s the 2 bolts more to the left...this is after I?ve taken all the other parts out again...
I can't believe how I could be so stupid..I do everything with lots of care...and then this happens!!!
I've also found this on ebay...my bike is from 1976, so it's a K6, do you think this will be ok if I buy it?
Or can I repair the broken ones?
http://cgi.ebay.co.uk/Honda-CB-750-F1-SOHC...1QQcmdZViewItem
Thanks for all replys!!!
JP
Post edited by: admin, at: 2005/10/26 11:32[img size=150]
Post edited by: admin, at: 2005/10/26 11:39
SammyB
Re:Broken bolts in cylinder head....help!!
« Reply #1 on: October 26, 2005, 09:31:19 AM »
DON'T PANIC
It's the studs for the cam towers, right?
First Job get yourself down to Halfords, or some other auto DIY shop and see if you can get a stud extractor. It should remove the studs easily, it works like mole grips, but fits on a socket wrench.
I have a spare head here, don't know what year, but if I can get the studs out cleanly I'll send them to you.
keeps us posted.
:blush: PS. I did the same thing the first time I used a torque  wrench, only I stretched 4 cylinder studs before, and snapped a fifth before I realised what I was doing wrong:P
[JP]
« Reply #2 on: October 26, 2005, 10:33:27 AM »
haaa....
So I can take those studs out of there?!
I tought they were welded in the cylinder head...humm...I'm more happy now than I was yesterday...pfffff....
I'm going to try to take them out tonight when I get home...
So..it means that it has 2 threads?one that goes into the cylinder head and the other one where the nut goes on top?
sorry for my english I hope you can understand it....
cheers,
JP
Offline JonnyHonda
« Reply #3 on: October 26, 2005, 11:12:40 AM »
SammyB is right, they are just studs, here is one I took out earlier, I used two nuts locked together, but I don't think you'll have enough thread.
They shouldn't be that tight, but if you have a problem gently warm the head and use either a stud extractor or a pair of mole grips.
[JP] wrote:
Quote
haaa....
cheers,
JP
[JP]
« Reply #4 on: October 26, 2005, 11:32:32 AM »
hoo..that's great!
I'm so relief now..I had a lot of work cleaning the valves and being very carefull with everything and this happened...and I tought I would need a new cylinder head...
many thanks for all your help...
Do you mind if I had a link in my webpage to this site?
As this helped me I think more people might find it usefull.
SammyB.... I would be very thankfull if you can send me those studs...if you are near you can come for a cuppa and see the bike!
I'm near Newbury.
Cheers,
JP
aka Pedro
admin
« Reply #5 on: October 26, 2005, 11:46:11 AM »
Well I'm please that was resolved, it just goes to show that if you ask the right questions we all get a result,
Thank you every one.
JP, SammyB has requested that you send your address in an email to me at webmaster@honda-sohc.co.uk and I'll pass it on.
Thanks again every one. and Keep Posting
Admin
[JP]
« Reply #6 on: October 26, 2005, 01:52:59 PM »
Once again..thanks to everyone!!!
I'll keep everyone updated with the project....which for someone like me that didn't know a thing about bike mechanics 1 year ago...I think it's going pretty well.
Admin, about the link, can I add it to my webpage?
admin
« Reply #7 on: October 26, 2005, 06:14:05 PM »
Yep add the link, and send me the address to your site and I'll add to our links too.
[JP]
« Reply #8 on: November 03, 2005, 08:30:58 PM »
:S  can
Offline JonnyB
    • BatchScan
« Reply #9 on: November 04, 2005, 10:03:11 AM »
I don't use the torque wrench for the smaller bolts,I bought one from Halfords but found the \"click action\" was so soft low down, that I missed it.
For small stuff, I use the 1/8th turn method, you tightnen up with as normal, then give it an extra 1/8th of a turn to tighten it up.
To remove a half snapped stud or bolt, you need a stud extractor. something like this
http://www.drapertools-online.com:8080/b2c/b2citmdsp.pgm?pp_skmno=14156
Which bolt have you snapped?, one of the ones holding the cam carriers down
Regards and Ride Safe!!
Daily Ride - BMW K1200GT
Summer Fun - Naked K100
Current Project - GS500E
John
https://batchscan.co.uk/
[JP]
« Reply #10 on: November 04, 2005, 10:29:17 AM »
yes..it was this one...
Post edited by: admin, at: 2005/11/04 16:41
Offline JonnyB
    • BatchScan
« Reply #11 on: November 04, 2005, 04:51:04 PM »
To get that out your going to have to take the cam assembly off again.
As I said before, your options are limited:-
Stud extractor, Mole grips, an engineering company to try and remove it or a onother head.
I have a head, but it has no valves,
Is that engine still in the frame?  If so I didn't think you could remove the camcover without dropping the engine
Good luck
John
[JP]
« Reply #12 on: November 04, 2005, 05:18:51 PM »
Hi.
yes..that engine is still on the frame, but that picture is old, the engine is now out of the frame.
so...went today to the shop that sold me my torque wrench and in fact it wasn
