Author Topic: Electronic ignition and light repair.MOT  (Read 4428 times)
Offline kevski
« on: February 19, 2019, 10:00:14 PM »
Added a Dyna-s to the 350f today, makes a lot of difference to start up, repaired a sealed light unit by converting to H4, got a new unit on order though, and put a tail tidy on my Z Thou [ Guests cannot view attachments ] [ Guests cannot view attachments ] [ Guests cannot view attachments ]
Would have MOT'd it last Saturday but for the light, so took it today and she passed the light set up and aim was perfect, i will still MOT my bikes even though they don't need to be , will still change it when new unit arrives though.
« Last Edit: February 22, 2019, 09:18:55 AM by kevski »
Re: Electronic ignition and light repair.
« Reply #1 on: February 19, 2019, 10:23:58 PM »
That's 2 mods that have improved my bike too;  the Dyna S and the H4.
Tip. Use some threadlock on the securing screws on the Dyna sensors.  One of mine came loose and I lost half of my sparks. Use some more heatsink  compound if you have some.
« Reply #2 on: February 19, 2019, 11:11:35 PM »
   those are worthwhile mods,the head light is easy if you find an auto electrical specialist,
they will have the light units and bulbs and sockets at trade prices .
 just remember to ride quicker, as you need to keep the engine spinning to charge the battery !!!!!
Offline kevski
« Reply #3 on: February 20, 2019, 06:28:29 AM »
Will be going back to right headlight when it gets here, i also have a electrex world reg/rec which has improved charging, old units weren't charging properly.
« Reply #4 on: February 20, 2019, 07:56:22 AM »
Dyna-S made a big difference on both my GS1000HC and CB750F2. Can't really understand why people stick with points, or do they still have a black and white TV with vacuum tubes? Especially with the points that are available (Daichi) they are rubbish.
Offline kevski
« Reply #5 on: February 20, 2019, 05:13:10 PM »
Already done Mike, cheers anyway.
Offline kevski
« Reply #6 on: February 20, 2019, 05:17:01 PM »
I believe the points and condensers are original, Nippon Denso's, bike still only less than 5.5k on the clock.
Offline kevski
Re: Electronic ignition and light repair.MOT
« Reply #7 on: February 22, 2019, 08:05:54 PM »
Took it for MOT today, straight through, improvised H4 light perfect, stroke of luck i thought.
Offline Moorey
« Reply #8 on: February 23, 2019, 08:47:16 AM »
Maybe its about trying to keep them as original as possible or is it ok to bin something because you can't see it.
Offline kevski
« Reply #9 on: February 23, 2019, 08:58:17 AM »
For me it's personal choice, i keep the original parts in case the next owner wants to return it to original spec.
« Reply #10 on: February 23, 2019, 10:03:41 AM »
I do exactly the same thing as you Kev. Personally I prefer the starting and running improvements plus the no maintenance bonus over the originality. I doubt it would sell for less because it has electronic ignition fitted and came with the standard parts. Maybe I wouldn't fit it to a nut and bolt perfect Sandcast, but it's a 750F2 that gets used daily in the summer.
