Author Topic: Rebuilding carbs, need some advice!  (Read 2865 times)
Offline xriccix
« on: March 04, 2019, 10:06:12 PM »
First job I want to get sorted is the carbs. This is the set that came with the bike, from what I can see right off the bat there are a few missing bits, a couple of nuts, throttle return spring and the bottom connector for the throttle return spring, I cannot seem to find a name for the damn thing or where to buy one??
Apart from being filthy the carbs look good, took the bottoms off and looks clean inside, I'm still debating a full rebuild. I guess it will come down to if i used a bread box or velocity stacks and therefore might need to use different jets.*
Re: Rebuilding carbs, need some advice!
« Reply #1 on: March 04, 2019, 10:52:21 PM »
Plate spring setting 16066-300-004
Offline xriccix
« Reply #2 on: March 04, 2019, 11:05:40 PM »
Perfect thanks! Now just to find one in the uk!
« Last Edit: March 04, 2019, 11:09:50 PM by xriccix »
Offline xriccix
« Reply #3 on: March 08, 2019, 01:32:10 PM »
In regards to the above set of carbs, I'm planning on taking of the mount and giving then a good clean. I might paint the bowls and round tops black, im not sure yet.
What would be the best way to clean the crap off, just degreease and a stiff brush?
« Last Edit: March 08, 2019, 03:48:23 PM by xriccix »
« Reply #4 on: March 11, 2019, 12:55:50 PM »
They should clean up quite easily with degreaser and a bit of metal polish... the bowls usually come up very bright with a bit of a polish.. no point going mad with the polishing though, as they will soon tarnish and settle back down to a standard greyish look. With some fresh rubber boots and bright hose clips they will look great.
Offline xriccix
« Reply #5 on: March 11, 2019, 01:47:03 PM »
Thanks, just waiting on a few parts before breakdown and clean!
