Other Stuff > Misc / Open
OIL AGAIN long read but interesting
Trigger:
Doesn't a oil debate trigger a DONATION reminder :o Gledhill, there is a box at the top of the page for you ;)
K2-K6:
--- Quote from: sye on May 10, 2019, 05:49:57 PM ---
--- Quote from: Trigger on May 10, 2019, 01:36:42 PM ---What a load of twaddle. You can use car/truck/bus oil in a bike, as long as the spec is correct ;)
--- End quote ---
And that's the important bit. If the spec is correct it matters not whether it's car, bike, marine or lawn mower oil.
--- End quote ---
Entirely right, it's when they mix up the technical requirements with branding and profit margin for their brand that it skews the apparent choice. what they rush you for their preferred oil is just commercial, using the correct spec is sensible but they don't often want the two separate for client interpretation.
The HD issue you had Dave is one of those examples if you can find more of these that prove the point about speciation. It doesn't always occur but searching what brings up a similar trail more or less confirms that those components are marginal for longevity if not being extremely diligent about lubrication. Generally they become known issues a bit like bomber exhaust cam.
A friend's Buell 1200 had an ominous big-endy rattle just as you blipped it from tickover, thought the worst, tried to trace it, couldn't get anything conclusive pinned down from the engine. Then when moved away from it, it sounded like it came from the front of the bike. Turned out to be the horn casing rattled against the fork leg in time with that chunky firing just as you snapped throttle open ;D It just resonated a clank like a knackered big end.
paul G:
--- Quote from: Trigger on May 10, 2019, 06:26:02 PM ---Doesn't a oil debate trigger a DONATION reminder :o Gledhill, there is a box at the top of the page for you ;)
--- End quote ---
It's not that bloody long since I did it ::)
Trigger:
--- Quote from: paul G on May 10, 2019, 08:34:34 PM ---
--- End quote ---
--- End quote ---
There is the word "long" and all you have to do is put a too in front ;D
paul G:
--- Quote from: Trigger on May 10, 2019, 08:41:47 PM ---
--- End quote ---
--- End quote ---
--- End quote ---
Done bloody Don Don Corleone :D
Navigation
[0] Message Index
[*] Previous page
Go to full version
