SOHC.co.uk Forums > Anorak's Corner
Carb setting for pod filters etc
<< < (2/2)
Andych:
That is perfect and a great read.... wouldnt it be good to have a Dyno in the back yard that allowed you to run full and part throttle :)
K2-K6:
It would be interesting to be able to test things like that on your own dyno if you run modded stuff.
I think that most bike riders can feel flat spots, hesitation etc as we're pretty well attuned to bikes that don't work well. It's the diagnosis of cause and coming up with something to correct it that's the difficult bit.
Or if it's a fault as opposed to setup/service problem.
K2-K6:
Apart from sounding good,  there's an interesting view of intake stand off in this clip. The fuel when the engine is under full load is being pushed out above the intake bellmouths which you can see as a fine mist. It's a normal function of intake dynamics which you don't often see.
https://m.youtube.com/watch?v=y2iBbwocYZw
What relevance can it have here,  do I hear anyone ask?   :)
Well,  I've been reading a contemporary test of  Honda's 750 F2 that was "tuned" which they ran it on a dyno by removing the rear wheel and connecting directly with drive chain to dynamometer.
One of the problems it suffered was a huge flat spot in mid range revs, poor enough to prevent them from getting stable consistent torque reading from. It was fitted with bellmouths and they noted that during the flat spot it had a huge fuel standoff out where the airbox should be,  which is what you see in that video but of course you'd not be able to observe it while riding.
One of the things an airbox does is to provide a plenum isolated from outside atmosphere. The standoff in this is better ingested to help engine running and also promotes scavenging from one cylinder fuel to another dependant on firing order (cross talk). The mist is already well mixed and atomised so works well in helping promote good combustion and driveable engine conditions too.
Greg65:
A very interesting article and the final nail in my podded Suzuki GS 1000 set up. When I brought it I found it had been up jetted by 10 stages, you could smell the richness. Settled on 3 steps up and it goes well under full throttle, but as the article suggests I have low end flat spots. So I think it will be a lot easier to return to original set up as that is what is was designed for, far better brains than mine have spent many hours on the problem and that’s their solution.
K2-K6:
It may be of interest for your application as the writer of that article, I think, is still in related trade http://www.emeraldm3d.com/about-us
As far as I know it's the same person,  journalist and tech editor at that time on motorcycle mechanics,  could be interested in a mod for your carbs and worth a question to them I suppose.
I've read alot of his projects and always they are very factual and honestly prepared, always reporting the downside as well while searching for improvements. A very informative writer.
Navigation
[0] Message Index
[*] Previous page
Go to full version
