SOHC.co.uk Forums > CB500/550
Copper Washers on Cylinder head cover and side covers
Bryanj:
Never noticed copper colouring on any of those, perhaps the zinc plating had not worn off as most of the ones i did were 1st time strip.
Erny:
Reopening this topic - are mentioned washers fine to be reused (after check and eventual flattening /grinding) or needs to be replaced by new ones? HSM does not specify this.
Tomb:
Any copper washers can be re-used if not damaged, copper work hardens so will need heating to cherry red colour and leaving to cool to anneal, they are then soft and should not need flattening/filing as they will do that when tightened down against. Of course this may remove the plating.
I make copper head gasket for my 4 cylinder bikes which I re-use in the same way.
Bryanj:
Back inthe day they were rarely replaced unless leaking
Erny:
Great, thanks
Navigation
[0] Message Index
[*] Previous page
Go to full version
