Author Topic: Engine oil use?  (Read 14500 times)
Re: Engine oil use?
« Reply #45 on: June 16, 2020, 10:40:07 PM »
That's better, not like the Torrey Canyon now then. Enjoy.
Re: Engine oil use?
« Reply #46 on: June 17, 2020, 06:27:27 AM »
Not me. We watched it on our old black and white TV.
The RAF bombed it to bits to try and burn off the oil. I think they only helped spread it though.
Offline Orcade-Ian
    • Older Vehicle Web
Re: Engine oil use?
« Reply #47 on: June 17, 2020, 07:57:36 AM »
You are opening up an old wound Steve and Julie,
The RAF used the Buccaneer - the plane I was involved with, to bomb the ship - about the first time it had been used in anger since it was put into service and guess what?  IT MISSED!  :)🤬
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Re: Engine oil use?
« Reply #48 on: June 17, 2020, 08:23:55 AM »
Yup, several times as i remember!!!
Offline TrickyMicky
Re: Engine oil use?
« Reply #49 on: June 17, 2020, 10:02:00 AM »
Re. The Torrey Canyon incident, if my fading memory serves me correctly, the RAF actually used Napalm to burn off the spilt oil, which caused a hell of an outcry because everybody was under the impression that we did not possess this weapon.
Offline SeanFD
    • Belfast-2-Belfast-By-Bike
Re: Engine oil use?
« Reply #50 on: June 19, 2020, 08:21:33 PM »
If you are not too sure or don't feel too confident doing this, maybe consider taking it to a garage for them to do. But yes, remove all the spark plugs. I would 'feel'  the top of one of the end pistons through the spark plug hole by resting something like a screwdriver on the top of the piston to determine where in the barrel the piston is sitting ....
🤣🤣 I’m just reading this post for the first time and this reminds me ....
Back in 1975, I was the proud owner of a CB125S with a massive fairing, bought at auction for, I think, less than £100; my first bike. One fine day I was trying to set the timing or check tappets or something; totally inexperienced and ignorant with only, maybe, but I can’t remember, a Haynes manual for guidance.
Anyway I was trying to determine TDC, so I thought to put a pencil into the spark plug hole and see when the piston got tot the top. I turned the engine over using the kick start, the piston came up and ..... yep, snapped the pencil in two. Thus began my career as an amateur motorcycle mechanic.
What surprised and delighted me most was that the bike actually started when I put it all back together again. I don’t think I had such a joyful moment until 40-odd years later when my rebuilt 750 K2 fired up on the first push of the start button.
« Last Edit: June 19, 2020, 08:33:09 PM by SeanFD »
CB750 K2 - See: Belfast2BelfastByBike.com
CB450 K1 - A work in progress. (Still!)
