Author Topic: Black piston ring (single)  (Read 3620 times)
Offline Sprocket
« on: June 02, 2019, 03:21:54 PM »
Any chance someone has a single (new) black piston ring i could buy? I have a cruzinimage standard size piston set, all went together ok but i ham-fistedly broke a black one when my feeler gauge slipped.  :(
Re: Black piston ring (single)
« Reply #1 on: June 02, 2019, 09:19:52 PM »
Unfortunately can't help you with the piston ring. I'm still trying to work out what you were doing with the feeler gauge near the piston ring once fitted 🤔🤔🤔
« Reply #2 on: June 02, 2019, 09:29:12 PM »
What size engine is it for, not that i got any but might get you more help.
« Reply #3 on: June 03, 2019, 07:18:47 AM »
Whatever you do, don't email Cruzinimage asking for rings. I did just that about 12 months ago. I didn't get a reply and they blacklisted me on eBay, people asking questions are troublemakers. So now if I want to buy off them I have to order direct from their own website. Not completely bad as their website is cheaper than eBay. They are a really strange bunch of people. And while were at it, don't buy anything off them that has rubber components or gaskets, they are total shite.
Offline Sprocket
« Reply #4 on: June 03, 2019, 08:12:05 AM »
They weren't 'fitted' at that point. Being very worried about splitting a ring, I was being really careful and used two to cover each of the ends of the ring as it went over the top gap, so it couldn't drop in where I didn't want it. (bit like this:
Then it slipped...
Offline Sprocket
« Reply #5 on: June 03, 2019, 08:15:08 AM »
You won't believe this then, I asked a question on the ebay listing 'can I buy a ring, I've broken one' and they emailed me straight back. Total cost is £17, which waters my eyes a bit, but at least it'll be from the same supplier so I know what I'm getting. :D
Cheers all!
« Reply #6 on: June 03, 2019, 08:39:14 AM »
If they are sending you a replacement ring, you will get one set and with the post is a good price. You should only put rings on shown in your picture if, it is a one part oil ring. Three part and the other two can be put on by hand  ;)
Offline Sprocket
« Reply #7 on: June 03, 2019, 10:07:08 AM »
I experimented. That was my problem. I got two pistons done by hand just fine. And then the 3 part oil scraper on number 3 was fine. Then I had the bright idea. ::) Then I did number 4 just fine without, too.
Thing is, you don't learn how rings break until you break one! If this project has taught me one thing it's to admit mistakes and learn. :D
