CB350/400
oil seals
Topic: oil seals (Read 3752 times)
rosco
SOHC Member
oil seals
July 10, 2019, 03:55:03 PM »
Engine rebuild coming on fine, after Head rebuild and rebore by Trigger. Just one problem I didn't fit the right hand crank seal before bolting the cases back together. I now not sure which way it fits. Logic says looking at it , the metal side out. Is this correct ?
Thanks Ross
royhall
Keep biking I'm not quite bankrupt yet
Re: oil seals
July 10, 2019, 05:36:18 PM »
You will be lucky to get it in as there is a rib around the seal that locates in a slot in the crankcases.
Nurse Julie
Re: oil seals
July 10, 2019, 05:45:34 PM »
Back to night school Ross. Metal side facing in...it should have a lip on it which needs to locate so cases need to be apart to fit it
royhall
Re: oil seals
July 10, 2019, 05:56:03 PM »
That said I have managed to change a seal before without splitting the engine. At least you don't have to get an old one out. What I did was coat the outside of the seal with grease and oil the inner then knock it in with a suitable size socket ( just smaller than the seals outer). Mine just popped in and has been fine since. Be very careful you don't accidently scratch the crank or your seal will be toast in no time. Good luck.
rosco
SOHC Member
Re: oil seals
July 10, 2019, 07:03:33 PM »
Bummer!! Thanks guys Back to schooooool !!!!!!!!! As I'm waiting for some parts from D S America to arrive Think its safer to split cases and do the job properly Ross
Nurse Julie
Re: oil seals
July 10, 2019, 07:05:22 PM »
Yes Ross, best to do it properly, a bummer I know but do it right, do it once 👍👍👍
royhall
Re: oil seals
July 10, 2019, 07:08:50 PM »
Agreed, splitting the cases is the best way to go.
rosco
SOHC Member
Re: oil seals
July 10, 2019, 08:08:49 PM »
Luckily I've got time on my side and not in a rush Just that the manuals are very vague and not fully informative Not like the forum Your right Julie do it once and do it right Better to find mistakes at this stage Least i can leave the Barrels and Head on Ross
rosco
SOHC Member
Re: oil seals
July 11, 2019, 03:44:53 PM »
Engine split, Seal fitted, and all back together. Thanks for your advice Julie and Roy It had to be done properly. Didn't dare risk it, then have to pull the motor out thanks again Ross
royhall
Re: oil seals
July 11, 2019, 03:52:02 PM »
Nice one, good decision. Bet it didn't take long once you got stuck in.
rosco
SOHC Member
Re: oil seals
Reply #10 on:
July 11, 2019, 03:57:46 PM »
It was really quick. Luckly all still fresh in my mind around a couple hours give or take Hardest part was lifting the engine and turning it over and round A bit of a lump ?? Ross
CB350/400
oil seals
