SOHC.co.uk Forums > CB750
Hot CB750 F1
royhall:
Does the glass act as a magnifying glass. That looks pretty severe. Pete Horton would probably fix that for you with some good quality faces.
Rob62:
Are those original faces or after-market replacements?
Skoti:
Original faces.
kent400:
Seen a few warped ones but never one quite like that bad and if the damaged area is touching the needle it can damage the gauge.
I have a spare used face that quite good if that will help. I would carefully inspect the tachometer face, can't see the heat would have only damaged one and not the other!
Skoti:
Kent400,
thanks for the helpful offer of a replacement face but I've been lucky enough get a used replacement clock from the UK via Flea Bay.
My wife was happy with the damage as I was prevented from exceeding 70MPH in case the needle became stuck on the melted speedo face!
Tacho face seems OK, bike was parked with the steering locked and handle bars on extreme right hand lock with speedo uppermost. Not sure if this was a factor, maybe just the way the sun was hitting it?
Navigation
[0] Message Index
[*] Previous page
Go to full version
