Author Topic: First Ride Out  (Read 3703 times)
Offline ace cafe racer
First Ride Out
« on: August 28, 2019, 08:28:58 PM »
Well took the old girl out for first time (for me) tonight. Well impressed with pulling power and handling. Only problem found on this run was a lot of popping from exhaust on overrun.
1977 Honda CB750 F1
2000 500 Royal Enfield Bullet
Re: First Ride Out
« Reply #1 on: August 28, 2019, 09:02:16 PM »
You will have a lot of popping with pods and they like a exhaust with back pressure. You can't have much front braking power with a small disc and a caliper that looks like its from a 400/4  ;)
Re: First Ride Out
« Reply #2 on: August 28, 2019, 09:31:22 PM »
Braking seems OK, but then again I am used to drum brakes lol. will have to look into that as front brake cylinder is seeping despite a new rebuild kit being installed. Wheel is 19 which I believe is larger than standard, Disc is 12 inch diameter is that needing to be larger? It does look smaller in the photo I must admit.
1977 Honda CB750 F1
Re: First Ride Out
« Reply #3 on: August 28, 2019, 10:10:28 PM »
19 is the original size.
Re: First Ride Out
« Reply #4 on: August 28, 2019, 10:19:16 PM »
thanks, so is the disc needing to be larger? if so what size disc do I need.
1977 Honda CB750 F1
Re: First Ride Out
« Reply #5 on: August 28, 2019, 10:32:19 PM »
I would stick with what you have as, it is not a case of just change the disc. You will need a disc, caliper and a brake arm .
