SOHC.co.uk Forums > CB350/400
Honda 400f four switchgear advice
<< < (3/3)
10tenmen:
--- Quote from: mattsz on September 01, 2019, 09:42:50 PM ---My pleasure - glad my bike is good for something!  Good luck!
--- End quote ---
Right so I now have lights working via the switch, my tail light is still on with ignition so that’s my next fix lol.
10tenmen:
Thanks to everyone it’s alive all lights now working it turned out there was a permanent ignition live to the rear light I simply Re connected and it’s now working via the switch, I had to email Davis Silvers for the switch wiring diagram as the colours were slightly different, I fitted new throttle cables to the switchgear and it’s running sweet now waiting for dvla to give me a reg number so I can get out on it.
Great forum thanks all.
mattsz:
--- Quote from: 10tenmen on September 02, 2019, 03:17:22 PM ---Thanks to everyone it’s alive all lights now working it turned out there was a permanent ignition live to the rear light I simply Re connected and it’s now working via the switch, I had to email Davis Silvers for the switch wiring diagram as the colours were slightly different, I fitted new throttle cables to the switchgear and it’s running sweet now waiting for dvla to give me a reg number so I can get out on it.
--- End quote ---
Would you mind forwarding that DS wiring diagram to me?
10tenmen:
Attached as it came hope it assists thanks Gary
Our technicians who refurbish our CB400F projects have told me that ;
Black/brown wire in right switch goes to brown/ blue on harness . This brown/blue harness wire is all brown with a blue cover over the end terminal.
Black/yellow on l/h switch goes to black/yellow on harness .
Black /yellow on right switch goes to a black wire on harness with multi socket on end .( 4 female sockets)
mattsz:
--- Quote from: 10tenmen on September 02, 2019, 06:32:09 PM ---Attached as it came hope it assists thanks Gary
--- End quote ---
So it's just that description and not a pictorial diagram then?  Ok, thanks!
Navigation
[0] Message Index
[*] Previous page
Go to full version
