Other Stuff > Misc / Open
Oversize Gudgeon Pin for Honda
<< < (2/2)
AshimotoK0:
Interestingly, a NOS S90 pin is ID 10mm  OD 14 mm and a CB350K one is also ID 10 mm but OD 15mm  so I am considering getting a 15mm pin ground down to 14.1mm ... Anyone know if the standard Honda gudgeon pins are the same hardness thoughout or surface hardened?
hairygit:
Ash, I can see you obviously want to use as much of the original parts as possible, but from what I can see it's cheaper to get a new rod. By the time. You have paid someone to grind down a gudgeon pin, and ream the little end and piston, you may as well but a rod kit and fit new parts. Conrods for all 6volt ohc 90 engines are the same original part no 1320 102 8000, now superseded to 1320 102 8010, and shown as in stock at CMS and available to order at DSS. Also good quality pattern ones out there. After all, is your little end wear small enough that 0.1mm will sort it? And of course, it means an irreversible mod to the piston too.
AshimotoK0:
--- Quote from: hairygit on September 13, 2019, 11:03:13 PM ---Ash, I can see you obviously want to use as much of the original parts as possible, but from what I can see it's cheaper to get a new rod. By the time. You have paid someone to grind down a gudgeon pin, and ream the little end and piston, you may as well but a rod kit and fit new parts. Conrods for all 6volt ohc 90 engines are the same original part no 1320 102 8000, now superseded to 1320 102 8010, and shown as in stock at CMS and available to order at DSS. Also good quality pattern ones out there. After all, is your little end wear small enough that 0.1mm will sort it? And of course, it means an irreversible mod to the piston too.
--- End quote ---
Know where you are coming from but sounds to me like paying and trusting somebody to strip and  re-align the crank would be quite costly/risky and too-ing and fro-ing in post kind of puts me off. I can get the engineering done for free (lots of people owing me for electronics work I have done or them for free  ;) ) Clearance on little end on my crank  is about 1.5 thou " , 0.1mm equates to 4 tho " ...so should be OK with 0.1 oversize pin.
Johnwebley:
I was looking through the Haynes manual for the CB200. and they claim that 0.1 over sized pins are available
Bryanj:
Probably same pin.
Navigation
[0] Message Index
[*] Previous page
Go to full version
