SOHC.co.uk Forums > CB350/400
Wobbly brake lever
K2-K6:
Oooops, at least you found it before it became critical :)
Bryanj:
What rubber bung? The lever pushes direct onto the master piston, or at least should do
Sprocket:
It's the bit the lever rests against, looking at the diagrams if you take the bottom nut off the lever, the plate comes off, and the rubber bung goes in the hole next to the pivot bolt. So when the brake lever is at rest, it's squashing the rubber tube.
I think?
Nurse Julie:
Isn't that the anti rattle bush thingy 🤔 No 224. P/N 45526-341-000
billywingnut:
I had wobbly front brake lever. parts 224 225 on the above drawing. the hardened pin was missing. I made a pin from out of a chain cut to length. I managed to find the retaining 225 part which fits underneath from a box of bits supplied with the bike. Works fine now .
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
