Author Topic: Batteries, charging and marginal systems...  (Read 4469 times)
Offline Tomshep
« on: December 23, 2019, 05:59:16 PM »
Nothing more to say.
« Last Edit: December 23, 2019, 10:08:06 PM by Tomshep »
Re: Batteries, charging and marginal systems...
« Reply #1 on: December 23, 2019, 08:28:55 PM »
Hello Tom and welcome to the UK forum.
« Reply #2 on: December 23, 2019, 08:31:58 PM »
My reply to your question above is keep it simple and keep it standard, keep every connector in good fettle and... she should fire up and run perfectly all the time, every time.
« Last Edit: December 23, 2019, 08:33:44 PM by Nurse Julie »
Offline Moorey
« Reply #3 on: December 23, 2019, 09:12:48 PM »
Welcome to the forum. If you are having to use your starter for 30secs. Look for your real problem because its not your battery.  ;)
Offline mattsz
« Reply #4 on: December 25, 2019, 11:04:26 AM »
Hmm... I don't see a question at all, Julie.  Am I missing something?
« Reply #5 on: December 25, 2019, 12:25:23 PM »
The first post was a synopsis of 400 four electrical capacity and influence that starting,  running,  generating etc has relevant to total system capacity as installed.  But now removed,  seemed a decent view for consideration in regards to running these bikes but now obviously not up for discussion  :)
Offline mattsz
« Reply #6 on: December 25, 2019, 12:28:02 PM »
Ah - that clears things up...  ;D
« Reply #7 on: December 25, 2019, 12:44:24 PM »
I was a bit confused too.  I put it down to “those 400/4 people”
Offline Moorey
« Reply #8 on: December 25, 2019, 01:05:11 PM »
Confused the #@%$ out of me, but I found the thinking highly flawed .
« Reply #9 on: December 25, 2019, 01:13:53 PM »
. No... I couldn't see a question either but just guessed that as I didn't understand a single word, there must be one there somewhere 😜😜😜😜
