Author Topic: Out and about 2020  (Read 117065 times)
Re: Out and about 2020
« Reply #225 on: September 22, 2020, 03:38:00 PM »
Happy 50th Julie x
Thanks James. I wish it were my 50th, my next one is my 60th 😁😁😁😁
« Reply #226 on: September 22, 2020, 09:45:25 PM »
Snapperwhipper!
« Reply #227 on: September 23, 2020, 07:51:02 AM »
Happy 50th Julie x
So you will have a nice little box coming from the NHS then lol  :o :o :o ;D ;)
Offline Andrew-S
« Reply #228 on: September 23, 2020, 10:16:44 AM »
Happy 50th Julie x
Oh dear, sadly I understand this and have for the last 3 years...... :-[ ;D ;D
1972 UK XL250 K0 Motosport
1976 UK Z900 A4
2018 BMW R1200 GS
Offline cooleronthecoast
« Reply #229 on: September 23, 2020, 12:19:22 PM »
Happy 50th Julie x
Me too.  :'(
Now where did I put that 10mm socket?
« Reply #230 on: September 23, 2020, 02:19:23 PM »
Haldex Hydraulics that takes me back .. really close to Fenner Fluid Power (SPX)  who I worked for in Rockford Il.USA  and our arch enemy competitors.
« Reply #231 on: September 23, 2020, 02:45:04 PM »
Seeing that you know so much about Haldex Ash, what you doing Saturday, I've got a heavy duty trolly Jack 🤣🤣🤣🤣🤣
« Reply #232 on: September 23, 2020, 04:19:05 PM »
Confused
« Reply #233 on: September 23, 2020, 05:43:11 PM »
HB Julie 🎂🍺🍺
« Reply #234 on: September 23, 2020, 06:19:19 PM »
Confused
There's no need to be confused Ash, what I'm saying is if I lift the car up on the jack you can remove and overhaul my Haldex pump as you understand them and I don't 😁😁😁.
To be fair, it's past an overhaul, its toast, so I need a new one. I'm just pissed off at the thought of paying nearly 2k, of which only £107 is labour, to have a new one supplied and fitted 😭😭😭😭😭
« Reply #235 on: September 23, 2020, 06:22:54 PM »
What is a Haldex pump?
« Reply #236 on: September 23, 2020, 06:32:31 PM »
The Haldex Unit is like a sort of clutch that distributes drive to each wheel automatically to maintain traction. On my Freelander it controls the drive ratio to all 4 wheels. There is a pump in it, pumping oil and that's all I know really John. On mine, not only has the internal pump packed up but it's also sort of eaten itself, so I can only drive in 2 wheel drive now (not a problem) but the drive ratio is all cocked up, and scrubbing out tires, so I need a complete unit. I'm still driving the car 🤣🤣🤣🤣
« Last Edit: September 23, 2020, 06:34:25 PM by Nurse Julie »
« Reply #237 on: September 23, 2020, 06:57:33 PM »
Wow.thats nasty.
But an oil pump!
It should last forever.
I assume it is sealed for life.and no oil changes needed.
Bit like auto boxes.
I was told change auto box oil every 40k miles.
It does deteriorate.
Best wishes
Out and about 2020
« Reply #238 on: September 23, 2020, 07:00:28 PM »
Quote
There's no need to be confused Ash, what I'm saying is if I lift the car up on the jack you can remove and overhaul my Haldex pump as you understand them and I don't .
ah I see now .. not available Saturday  but could come Sunday ... need to get stuff off Graham anyway & pay him !  :)
« Last Edit: September 23, 2020, 08:02:44 PM by SteveD CB500K0 »
« Reply #239 on: September 23, 2020, 07:16:12 PM »
Wow.thats nasty.
But an oil pump!
Best wishes
According to Land Rover its a sealed, non serviceable item and therefore there is no mention in the service schedule of cleaning the filter out and changing the oil every 2-3 years. But, Audi, Skoda, Volvo etc use the same unit and the dealers service them and repair them ( there's an overhaul kit you can get but that's still about £600 parts and labour). I could get the local independent Land Rover specialist to do the overhaul on the pump and filter but there's a very high chance I could drive up the road and the same problem occurs as the actual metal internals of my unit are knackered, so a false economy really. I suppose its the same as fitting a bike oil pump with new seals and O rings, if the working parts inside are shot, it's not going to solve the problem. Its a pain in the arse TBH.
« Last Edit: September 23, 2020, 07:18:19 PM by Nurse Julie »
