Author Topic: Rear brake retaining spring.  (Read 3084 times)
Offline Dolomite_
« on: January 05, 2020, 04:35:37 PM »
I've referenced some pictures and It appears that I have the retaining spring next to the rear brake lever in the right place but there still seems to be quite a bit of play in the brake lever. The adjuster nut on the wheel end is compressing the spring that end quite a lot and if I keep turning the nut to take out the play it will be fully compressed.
Could anyone upload some pictures of the 2 springs so I can compare?
Offline Moorey
Re: Rear brake retaining spring.
« Reply #1 on: January 05, 2020, 04:45:30 PM »
Are you sure the brake lever arm is in the correct position on the splines into the drum.
« Reply #2 on: January 05, 2020, 05:06:12 PM »
Also to add to the above, have you got the rear brake adjuster rod in the correct position at the angle part at the front? I will take a photo in a minute.
« Reply #3 on: January 05, 2020, 05:16:52 PM »
That's a piece or rubber on the end of the spring, so me frame doesn't get scratched 😊😊😊
« Last Edit: January 05, 2020, 05:18:45 PM by Nurse Julie »
Offline Dolomite_
« Reply #4 on: January 15, 2020, 06:59:48 PM »
Thanks all. Got that job ticked off, now onto the next one.
