General > New Member Introductions
550 top and bottom rebuild
<< < (3/3)
Trigger:
--- Quote from: Richie 550/4 on February 10, 2020, 04:43:24 PM ---Hi Trigger.
Do you have any suggestions on removing these plugs on the head? Is this a drilling out job or is there a clever way of removal? I take it from your mess these are not available for replacement and need to be machined?
Richard
--- End quote ---
It is only the centre slug that needs to be removed. Drill, insert a tap and connect a slide hammer to pull it out. You need a lathe to make new ones  ;)
Richie 550/4:
Hi Trigger
Thanks for the valuable advise. I owe you a drink or two
Trigger:
--- Quote from: Richie 550/4 on February 11, 2020, 08:51:01 AM ---Hi Trigger
--- End quote ---
You won't see that on a YouTube vid  :o  ;)
Richie 550/4:
Hi all.
Just a quick update on my progress with the rebuild.
So. I have the crankcase back together for the final fit. Just the primary shaft to fit and oil pump. I’ve been through the gears and all seems well.
Attached a few pics
Many thanks to those who have been so helpful coming forward with your advise and experience.
Richard
Richie 550/4:
Sad news!
I was picking up some parts from a local custom builder today, he had recently had a workshop fire and one of the casualties was a recently fully rebuilt CB750 early 70’s
A very sad sight indeed.
Hope he can salvage her?
R
Navigation
[0] Message Index
[*] Previous page
Go to full version
