General > New Member Introductions
Another 400/4 on the road
<< < (2/2)
rustywheels:
Its been a little while, but I’ve spent the time gradually working my way through the bike.
Biggest changes were the tyres (got rid of those very scary rubber for some Avon's) so feels just a bit happier now in the corners.  Also, had the tank repainted as per the pics - although I doubt you can see the difference, but it has improved the bike no end as the epoxy blobs have now gone
Now comes the bit where I admit to my mistake....
So, I thought I had a rich running bike.  Bit of a hole in the mid-range and wouldn't rev out, with very fouled plugs.  So naturally, I stripped the carbs, replaced jets and even invested in a sonic cleaner.  Many a happy few hours rebuilding and adjusting the needles before slotting them back into the engine.  Did you know a C clip for a jet needle can travel over 10ft by itself when trying to clip it back in?? All was well until the test ride (ie 10 mins).  Popping and banging, and no power at the top, but very clean plugs.  So now must be running lean?  Once more into the carbs we go and more adjustment of the needles, and more stuffing the b@ggers back into the engine.  No joy, still lean.
Much scratching of head, and after reading the entire contents of this forum, it transpires that as I have a Boyer electronic ignition, it doesn't like to have a resistor type plug and cap.  Swapping out the plugs for non-resistor standard plugs, and further removal of carbs to reset to standard settings, and we seem to be back in business.  Ugh! The only downside is that I am unable to test ride the bike to see how it all works properly until after the lockdown.
I guess you live and learn.  At least I now can remove Carbs in under 15 minutes and they are lovely and clean, so fingers crossed I won't have to do this again in a hurry.
simonc:
 8)v nice welcome
Mikie:
Hello and welcome to the forum Rustywheels, that's a nice bike. Best of luck with it.
Where and what type of an ultrasonic cleaner did you get? Are they worth it?
Regards, Mike
Laverda Dave:
Very nice bike 👍. The blue ones were indeed the fastest but that was before the yellow ones appeared 😁. Getting the carbs dialled in is a real pain especially when the rubbers have aged.
The paintwork looks fantastic.
Mikie, get yourself an ultrasonic cleaner. I paid £75 for mine, a two litre model. When you consider most companies charge £25 per carb to clean its a no brainer. As a tip though I would buy the three litre version, getting all the parts for one carb into a two litre tank is very tight.
Mikie:
--- Quote from: Laverda Dave on April 22, 2020, 01:33:40 PM ---Very nice bike 👍. The blue ones were indeed the fastest but that was before the yellow ones appeared 😁. Getting the carbs dialled in is a real pain especially when the rubbers have aged.
--- End quote ---
Thanks for that, Laverda Dave :)
Navigation
[0] Message Index
[*] Previous page
Go to full version
