Author Topic: 1978 CB550 K3 "running" restoration  (Read 56044 times)
Re: 1978 CB550 K3 "running" restoration
« Reply #90 on: May 01, 2020, 03:33:03 PM »
No problem, if it does turn out to be caliper piston you can pm me and i will give you ideas
Offline SPR
  • 1972 500/4 K1
« Reply #91 on: May 02, 2020, 10:19:14 AM »
So a big thanks to Bryan for his detailed help and verdict :)
Caliper off and taken apart - problem diagnosed and new piston and seal ordered together with new pads !
Caliper repainted and in the oven to cure :)
Hopefully the new bits will be here soon
Simon
Offline SPR
  • 1972 500/4 K1
« Reply #92 on: May 06, 2020, 03:18:28 PM »
Postie has been !!
Brake bits arrived and seat / horn in 3 days from the USA !!
Seat is like new !!
Spanner’s at the ready :)
Offline mickwinf
« Reply #93 on: May 06, 2020, 03:42:48 PM »
thats a nice looking seat!
Offline SPR
  • 1972 500/4 K1
« Reply #94 on: May 06, 2020, 04:22:29 PM »
It is :)
All done and all thanks to Bryan for his great instructions !
Front brake works :)
Seat on and decent horn to get rid of the modern one
Simon
Offline SPR
  • 1972 500/4 K1
« Reply #95 on: May 18, 2020, 09:42:20 AM »
So big day :) UPS will be delivering the new exhaust at some point
Old ones off - collars in oven cooking :)
I’ve new genuine crush washers to fit - should I be using sealant as well like Honda Bond or should this not be required ?
Simon
« Reply #96 on: May 18, 2020, 10:05:57 AM »
Only the crush washers required.
Offline SPR
  • 1972 500/4 K1
« Reply #97 on: May 18, 2020, 10:07:50 AM »
Excellent !
Just waiting now !!
Offline SPR
  • 1972 500/4 K1
« Reply #98 on: May 18, 2020, 02:22:30 PM »
I'm worried that Simon is one of those dudes in a full white suit, that looks like a quarantine tent  ;D ;D ;D ;D
You think the next room is full of Covid patients ????
How did you know !!!
It’s a classic car tent from Hamilton’s - has fans and zips up to provide a rigid bubble so no condensation in winter
« Reply #99 on: May 18, 2020, 02:44:59 PM »
Do you have a classic car to put in it?
Offline SPR
  • 1972 500/4 K1
« Reply #100 on: May 18, 2020, 02:50:34 PM »
No - I’ve just got rid of two Harley’s which filled it but it is great to be able to work on dry bikes during winter
The garage seems susceptible to condensation which kills Harley’s very quickly :) this has totally gone with this tent.
Offline SPR
  • 1972 500/4 K1
« Reply #101 on: May 18, 2020, 05:35:37 PM »
Success !!
Exhausts all fitted and must say the quality is very good
Old exhausts are available if anyone wants a set - one has been repaired previously and I think two are minus baffles .. some other pin holes in the others - £75 collected
The old exhausts
Offline woody928
« Reply #102 on: May 19, 2020, 11:35:53 PM »
I've just read through this whole thread having just picked up my own 1978 550 last night.
Really good to see you getting stuck in with all of the repairs and restoration, it looks like you're doing an amazing job at bringing the bike back to its former glory. I look forward to seeing what you do next, a lot of these jobs are going to be providing me with headaches soon enough!
Offline SPR
  • 1972 500/4 K1
« Reply #103 on: May 20, 2020, 12:17:05 AM »
If I can do it anyone can - especially with the help available on here !!
It really needs the tank painting
Offline SPR
  • 1972 500/4 K1
« Reply #104 on: May 30, 2020, 09:49:35 AM »
So .... another learning curve today ... carb balancing :)
Everything checked and double checked
I haven’t received the auxiliary tank so decided to have a go with what the floats hold - more to be a practice run
The carbs were all different - and quite up and down from #2
I was surprised how little you move the adjustment screw to make a big difference - explains I suppose why they can all look set ok but still be unbalanced.
The mercury gauge kindly donated by Ken worked great - it seemed most stable at around 2k revs.
So .... I learnt that I need the extra time as it is quite fiddly so will be having a second attempt when the tank arrives. I have got them better but not good enough.
It shows that a novice can do these and other jobs with help and guidance :)
The bike does seem to idle much smoother ... will take it for a blast to see if there is a noticeable difference
Simon
« Last Edit: May 30, 2020, 09:53:20 AM by SPR »
