Author Topic: 1978 CB550 K3 "running" restoration  (Read 57952 times)
Offline SPR
  • 1972 500/4 K1
Re: 1978 CB550 K3 "running" restoration
« Reply #105 on: April 30, 2020, 11:25:47 AM »
On the front wheel spindle there is a long but/tube, if you need to replace the bearings it has to be removed to get the spindle out. It is entirely possible that a previous owner has refitted the tube nut the wrong way, which moves the entire wheel assembly slightly to the left (from sitting on the bike in the normal riding position) allowing a very slight contact between the disc and fork leg.
Could you possibly say which bit I'm looking for on here ... I know I know  ::)
Offline SPR
  • 1972 500/4 K1
« Reply #106 on: April 30, 2020, 11:42:47 AM »
Offline SPR
  • 1972 500/4 K1
« Reply #107 on: April 30, 2020, 11:46:58 AM »
No 18.
My #18 is on the other side ?
I presume that could be the issue ... is it easy to swop ?
Stupid question - it wouldn’t have been done when tyres were changed ?
Offline hairygit
« Reply #108 on: April 30, 2020, 11:51:48 AM »
Looks like the spindle is back to front, the tube nut should be on the disc side of the wheel, that would cause your problem!
Offline SPR
  • 1972 500/4 K1
« Reply #109 on: April 30, 2020, 12:00:08 PM »
Many many thanks again !!!
Changed over ....
Offline SPR
  • 1972 500/4 K1
« Reply #110 on: April 30, 2020, 03:02:51 PM »
Forks all apart and new seals fitted .... just the slight problem of not being able to source fork oil !!
« Reply #111 on: April 30, 2020, 05:07:47 PM »
Got any atf? Even ordinary 10w40 will do at a pinch. Majour diff with fork oil is it dont "froth"
As to the rub mark if you mean on that black plastic bit(cant see anything on the alloy, but i am geriatric) it frequently gets the bracket bent or twisted.
Offline SPR
  • 1972 500/4 K1
« Reply #112 on: April 30, 2020, 05:55:24 PM »
the only oil I have is 15w40 diesel qx oil as used by a few on here for the engine
It was a wearing of the actual alloy leg - the spindle was the wrong way round and I've a feeling that the tyre change man altered it
Offline SPR
  • 1972 500/4 K1
« Reply #113 on: April 30, 2020, 07:22:34 PM »
Well ... quick trip to the garage and they had some 10w 40 so bike is all back together .... wheel now correct and disk not touching leg
So far no leaks !!!
A good day and as usual with help from you lot I've managed something else :)
Simon
« Reply #114 on: April 30, 2020, 07:40:30 PM »
You're doing very well Simon.
Offline SPR
  • 1972 500/4 K1
« Reply #115 on: April 30, 2020, 08:35:57 PM »
We'll reserve that till after I've been out on it :)
Offline SPR
  • 1972 500/4 K1
« Reply #116 on: May 01, 2020, 01:42:26 PM »
So a small issue after doing the forks ....
The front brake isn't moving freely on the arm that is supposed to swivel when the brake is applied ...... causing the brake to drag ... I can free it again moving the arm back with a screwdriver but it again starts to bind
I did take this all apart and cleaned the spindle bit and applied a small amount of red grease - was this wrong ?
Any ideas welcome
Simon
« Reply #117 on: May 01, 2020, 02:05:13 PM »
No it was right but it might be the piston in the caliper rather than the bracket. Undo the two bolts holding the caliper halves and see if the arm pivots free then.
BIG HINT
BEFORE attempting to undo the bleed nipple warm the alloy with one of the plumbers torches on dispoable canister or some such then use an 8mm deep socket with a tee bar so you get an even turning force. The bleeders snap off easily.
Also if you do need to get piston out pump the piston out with master BEFORE disconecting pipe.
Offline SPR
  • 1972 500/4 K1
« Reply #118 on: May 01, 2020, 02:06:49 PM »
BIG HINT
On it :)
Many thanks again
« Reply #119 on: May 01, 2020, 03:33:03 PM »
No problem, if it does turn out to be caliper piston you can pm me and i will give you ideas
