Author Topic: What do I need to fix my oil leaks?  (Read 17920 times)
Offline Drew400
  • 400/4 I restored
« on: March 22, 2020, 08:50:19 AM »
Hello all,
When I rebuilt my 400/4 some years ago, I didn't quite seal it properly so I have oil weeps from most of the major split points (i.e. cylinder head, block base, etc.). They're not bad enough to worry much about, I just wipe it over every time I use it... it's hardly old British bike territory!
However (you know what's coming), this enforced isolation business is a good opportunity to spend time in the garage fixing it.
My question is this:
I would like to buy all the bits I need to do the job IN ONE HIT (especially as some of it will come from David Silver and so I'd just like to pay one lot of postage please)! Is there anything else I need on my shopping list in addition to these items:
- Gasket set
- Oil seals set
- Head bolts (with oil seal washers)
- Hylomar or some such
Thank you, D.
Re: What do I need to fix my oil leaks?
« Reply #1 on: March 22, 2020, 09:14:30 AM »
Ditch the Hylomar from the list Drew. Its only the crank cases that need sticking together with the lightest, lightest smear of Honda Bond as they are machined surfaces and have no gasket. Other than than that the gaskets do the job everywhere else.
Offline Drew400
  • 400/4 I restored
« Reply #2 on: March 22, 2020, 09:17:29 AM »
Thank you Nurse Julie. Maybe using that stuff last time is my problem... not that I can remember what I did/didn't use!
« Reply #3 on: March 22, 2020, 09:19:24 AM »
Out of interest Drew, why are you going to use new head bolts?
Offline Drew400
  • 400/4 I restored
« Reply #4 on: March 22, 2020, 09:21:50 AM »
Can't remember that either, but I  know they leak all from the top if the wrong ones are used, so I guessed they can't be re-used.
No doubt when I actually start the work, some of this will come flooding back!
« Reply #5 on: March 22, 2020, 09:26:54 AM »
They can be re used with no problems at all Drew. No point in spending money on something that is not needed. When you are stripping the engine you just need to have a close look at what you did before that has caused the engine to leak.
Offline bobv7
« Reply #6 on: March 22, 2020, 10:26:26 AM »
To keep an awkward gasket in place I find a light smear of high temp grease helps.
« Reply #7 on: March 22, 2020, 10:27:54 AM »
Me too Bob 👍👍👍
Offline matthewmosse
« Reply #8 on: March 22, 2020, 10:42:39 AM »
Did you re torque all  the head bolts after a few miles riding? ( then check tappets ) been a long time since I did anything on an sohc engine so I am really rusty, might be worth trying. I have cured the odd leak with things like that - just not sure it's the totally correct fix.
« Reply #9 on: March 22, 2020, 10:48:28 AM »
Head is studs not bolts, some of the nuts have special "copperised" washers to seal oil and they ometimes need replacement but are dear.
Hondaman on the US site has worked out that modern gaskets are thicker so you need thicker cross section O rings to seal properly. Could be worth going there and asking him for sizes.
Retorque was never done in dealerships and if everything clean and flat shouldnt need it
Offline Drew400
  • 400/4 I restored
« Reply #10 on: March 22, 2020, 10:53:43 AM »
Thank you all for your wise council.
Bryanj - the copperised ones are the ones I was thinking of. I'll check out Hondaman too.
I think we can all agree, there's probably no rush to do this as I think we've all now got lots of spare time on our hands!
Stay well everyone.
« Reply #11 on: March 22, 2020, 11:37:13 AM »
You don't need new copper washers on the head studs. Heat them up to cherry red and quench them. This annealing process softens them so they seal better.
Hope it all goes well with the strip and you don't find anything narsty.
« Last Edit: March 22, 2020, 05:08:43 PM by mike the bike »
Offline Drew400
  • 400/4 I restored
« Reply #12 on: March 22, 2020, 11:45:43 AM »
Thanks Mike, will do. I'm hopeful it will still be like a clean sewing machine in there!
« Reply #13 on: March 22, 2020, 01:05:28 PM »
Unfortunately they are not solid copper but i think coppered steel
Offline Drew400
  • 400/4 I restored
« Reply #14 on: March 22, 2020, 01:15:36 PM »
Ah, thank you experts all. Cheer, D.
