SOHC.co.uk Forums > CB500/550
Fitting Taper Rollers to K3
PennoK3:
Problem is original balls are long gone so nothing for comparison.
Erny:
Ah, I see... I have then still somewhere, tomorrow I can check it if you want
PennoK3:
That would be great thanks.
Erny:
Here we are, I found them, measured for reference of anyone interested. These comes from my 750K7 but my 550K1 has the same, so I assume other sohc too (I advice to verify via spare parts catalogue)
Hope it helps
PennoK3:
Many thanks Erny. I think I have solved it now. Took of the washer/spacer from the bottom bearing, may have had the oil seals mixed up as I had the large one on the bottom but replaced it with the smaller one which now sits nicely inside the headstock. Larger seal covers the top and all has fastened up nicely. Many thanks for your help.
Navigation
[0] Message Index
[*] Previous page
Go to full version
