Author Topic: 550 k3 harness  (Read 5633 times)
Offline 3scs
550 k3 harness
« on: April 05, 2020, 10:24:03 PM »
Just fitting new main harness to my 550k3 it had the wrong harness fitted does anyone know the correct route does it go around the frame or through the centre of the frame
Offline Erny
  • CB750K7 CB550K1
Re: 550 k3 harness
« Reply #1 on: April 05, 2020, 10:34:58 PM »
Probably not exactly for K3 but should aswer your question
You can find it also here, section wiring diagrams (as pdf) http://manuals.sohc4.net/cb550/
CB750K7 US model (1977)
CB550K1 US model (1975)
Offline simonc
Re: 550 k3 harness
« Reply #2 on: April 18, 2020, 06:06:38 PM »
through frame
one job leads to another
cb72 1964
cb550f1 1976
cb550f1 1976
cb550 1977 with cb 500k engine
Offline 3scs
Re: 550 k3 harness
« Reply #3 on: April 26, 2020, 05:49:24 PM »
New harness fitted gone for round the frame although I thought it looked much tidier through the centre but as oddjob said possibly to make room for cables I would like to thank Big Al,Alan’s electrics  for making me the correct harness everything worked as it should and fitted perfect highly recommended
Re: 550 k3 harness
« Reply #4 on: April 26, 2020, 06:12:03 PM »
Lovely job by Al there Si 👍👍👍👍
Offline 3scs
Re: 550 k3 harness
« Reply #5 on: April 26, 2020, 09:26:26 PM »
yes spot on only problem I had but nothing to do with the harness was it wouldn’t start when I had finished would turn over but just kept backfiring after many hours of scratching my head luckily I’ve got into the habit of taking loads of photos of what I’m doing before I touch anything I noticed on the coils the blue was connected to the yellow and yellow to blue swapped them round and started straight away I’m sure there’s some reason it was like that but not quite worked it out yet
« Last Edit: April 26, 2020, 09:40:10 PM by 3scs »
Offline BigAl (Alan)
    • www.alans-electrics.co.uk
Re: 550 k3 harness
« Reply #6 on: April 27, 2020, 02:50:46 PM »
Thanks for the feedback Simon concerning the new wire harness (1st/2nd images)  Much appreciated.
I gather the (4th image) was the original harness before you sent it to me?
Alan
Current bikes:-
Honda CB750 K4 (1974) USA
Honda XL500S (1980) UK
Honda CD175 sloper (1968) UK
Honda CB1100A (2013) UK
Offline 3scs
Re: 550 k3 harness
« Reply #7 on: April 27, 2020, 06:34:06 PM »
Yes the harness in the fourth picture is the one which was fitted when I bought it I believe it either an f1 or f2 harness the bike originally had the wrong right hand switch fitted it had no kill switch on it I put the correct switch on but had to make it fit as you say the k3 has a block connector and not bullets there’s so many parts that are wrong on this bike and as trigg as pointed out to me it might of been easier to buy an f frame as I seem to have most of the bits for that
Offline 3scs
Re: 550 k3 harness
« Reply #8 on: April 27, 2020, 06:39:39 PM »
Alan
the harness I sent you was off my other k3 I bought as a doner bike depending on what I do with that one I might be after another one of your quality harnesses
Offline 3scs
Re: 550 k3 harness
« Reply #9 on: April 27, 2020, 06:44:22 PM »
This was the pic I meant to include
