SOHC.co.uk Forums > CB350/400
Horn
Trigger:
--- Quote from: Oggers on April 07, 2020, 10:39:41 AM ---Yes, I'm getting the strangled click! Very faint, but something does happen when I press the button. Continuity in the horn and when the switch is depressed is present, and yes, I have fiddled with the small screw at the back a little to see if that was the fault. Put back to original position. No big deal, just testing things after the wiring nightmare......
--- End quote ---
If the big nut on the back has been moved, it needs retuning ;)
Oggers:
Trigger - the big nut on the back has definitely moved as I took the horn off its brackett! i did wonder if it has an effect. Do you retune with this nut or the small screw? - or both?
Oggers:
Appreciate a test would be to connect to a fully charged battery. I have no spare - so would crocodile clips to the car battery suffice? Obviously a car battery carries a greater punch - just afraid of damaging things
hairygit:
Car battery won't hurt it, 12voltsis 12volts, bike or car battery. (Provided it's a 12volt bike)
Trigger:
--- Quote from: Oggers on April 08, 2020, 07:52:42 AM ---Trigger - the big nut on the back has definitely moved as I took the horn off its brackett! i did wonder if it has an effect. Do you retune with this nut or the small screw? - or both?
--- End quote ---
If you put the small screw back to factory set. Then start tuning the big adjuster on the back, one you have the connection start on the small screw. Hard to explain this ;)
Navigation
[0] Message Index
[*] Previous page
Go to full version
