Author Topic: No spark  (Read 17841 times)
Offline yozzer74
No spark
« on: April 11, 2020, 08:02:19 PM »
Hello been a while I've bought myself a 400/400 needs plenty of work doing to it.engine turns over on start button but it as no spark. I've run a wire from battery to the coils to power them which then gives me a spark all be it a tiny one. Does anyone have any ideas what the problem could be. I've also done a compression test on it I'm getting 100 psi across all 4 cylinder.  My gauge is only a cheap thing off ebay so not too sure how accurate it will be. But should it run with that much compression?? Thanks in advance.
Offline yozzer74
Re: No spark
« Reply #1 on: April 11, 2020, 08:07:18 PM »
Offline robvangulik
  • Honda Fourever
Re: No spark
« Reply #2 on: April 11, 2020, 08:31:42 PM »
As you never know how accurate the gauge is, so long as they all have about the same pressure it should run fine.
Re: No spark
« Reply #3 on: April 11, 2020, 09:04:15 PM »
Kill switch or ignition switch could be faulty, clean and reset points and timing. If that really is compression its very low
Offline yozzer74
Re: No spark
« Reply #4 on: April 11, 2020, 09:37:18 PM »
the previous owner as fitted a new kill switch so that should be good. ill check ingnition switch out thanks
Offline yozzer74
Re: No spark
« Reply #5 on: April 11, 2020, 09:39:02 PM »
the bike is showing 28000 miles on clock .its not been run since 2009.
Re: No spark
« Reply #6 on: April 11, 2020, 09:57:35 PM »
With that time stood point def need cleaning, setting and timing doing also possible rings are stuck in pistons so be very carefull running it
Re: No spark
« Reply #7 on: April 11, 2020, 09:59:09 PM »
If he happens to have fitted the kill switch from a 400 twin it would work backwards as the switch is totally different electricaly
Offline yozzer74
Re: No spark
« Reply #8 on: April 11, 2020, 10:24:31 PM »
how would i know if hes done that then ??. also were is the best place to get new mudguards& Seat  for it david silvers ?
Re: No spark
« Reply #9 on: April 11, 2020, 11:13:41 PM »
Just try for spark in both on and off position.
Mudguard and seat at Silvers but sit down before you check price!
Offline Moorey
Re: No spark
« Reply #10 on: April 12, 2020, 12:32:31 AM »
Even with a crap gauge 100psi is way low.
Offline yozzer74
Re: No spark
« Reply #11 on: April 12, 2020, 03:41:16 AM »
no lights work only the oil light and start button. no i didnt hold the throttle open does it make a diffrence ?? ill give it a go like that see what results i get thanks
Offline mattsz
Re: No spark
« Reply #12 on: April 12, 2020, 01:59:34 PM »
I made that mistake... once.  Afterwards, I modified my compression test gauge to prevent future screw ups...
Re: No spark
« Reply #13 on: April 12, 2020, 02:30:49 PM »
At least you didnt write it on the glass!!
Offline mattsz
Re: No spark
« Reply #14 on: April 12, 2020, 02:43:34 PM »
I'm certainly a dumbass... but I'm not stupid!!!
