Author Topic: No spark  (Read 17843 times)
Re: No spark
« Reply #15 on: April 12, 2020, 02:30:49 PM »
At least you didnt write it on the glass!!
Offline mattsz
Re: No spark
« Reply #16 on: April 12, 2020, 02:43:34 PM »
I'm certainly a dumbass... but I'm not stupid!!!
Offline billywingnut
Re: No spark
« Reply #17 on: April 12, 2020, 08:01:22 PM »
Hi Yozzer74 welcome to the 400 owners club.
If you are unfamiliar with the 400, then you could do worse than to spend a few hours reading through this forum in particular Nurse Julie's build.
I bought mine in 2016, even if you don't want to return it to prestine condition ( which I didn't) be prepared to spend at least £2k and a lot of time to make it run properly and be reliable and safe, you need to got through the bike  completely.
I replaced the rings and one piston that was damaged ( pays to take the engine apart), it had 33K on the clock and the last Tax disk was 1998. I now get around 120 -125 compression using the same type of compression guage you mention. It will  do 70 no problem up a hill.
I found lots of bodges, in the wiring and fuse box etc.
good luck
Offline yozzer74
Re: No spark
« Reply #18 on: April 13, 2020, 04:59:51 AM »
Thanks think I'm going to need it. I was thinking of just buying a new wiring harness coils & points and taking it from  there.
Re: No spark
« Reply #19 on: April 13, 2020, 08:54:18 AM »
Points, possibly complete with plate to get rid of chewed scres yes, coils rarely fail and the loom can be fixed 95% of the time, unless its been hacked about of course.
Offline yozzer74
Re: No spark
« Reply #20 on: April 13, 2020, 09:54:46 AM »
bryanj to be fair the loom does look in good condition.
Offline yozzer74
Re: No spark
« Reply #21 on: April 13, 2020, 09:56:43 AM »
what way do you think i should go about this try get it running first or just jump straight in on strip down
Re: No spark
« Reply #22 on: April 13, 2020, 02:39:28 PM »
Get it running first
Re: No spark
« Reply #23 on: April 13, 2020, 05:38:15 PM »
I think you are right Yozzer get it to run first see how it runs /sounds. I bought a battery and oil and started it to find smoke and rattles, I'm glad I decided to  strip down because the sump was full of gunge both chains required replacing and the valves required re-grinding, the headstock bearings were notchy, basically all the things you would expect as part of servicing needed checking. The loom should be ok. I replaced the bullets and sockets on the ends of all connectors because i had intermittent issues with the electrics. I removed all bits of wiring that didn't belong ( heated grips etc)
Re: No spark
« Reply #24 on: April 13, 2020, 07:15:51 PM »
Heated grips??? !!!
Offline yozzer74
Re: No spark
« Reply #25 on: April 14, 2020, 09:39:23 PM »
Well managed to get bike to spark tonight. I did compression test again with throttle open .managed together 125 psi average across all 4 cylinders. Going to take carbs off tomorrow see what there like inside. One step closer to trying to start her .
Offline yozzer74
Re: No spark
« Reply #26 on: April 26, 2020, 03:20:12 PM »
Got a bit more time on bike today .removed carbs changed oil and filter .turned engine over till oil light went out .then sprayed easy start in through inlets.fired up pretty well after being stood for so long .https://youtu.be/mHhh0hXxAhs
Offline SPR
  • 1972 500/4 K1
Re: No spark
« Reply #27 on: April 27, 2020, 11:09:48 AM »
Result !! ...
Offline yozzer74
Re: No spark
« Reply #28 on: April 30, 2020, 11:59:20 AM »
Bought a new set of carbs for bike yesterday fitted them bike fired straight up .video of her running. https://youtu.be/kzCNWrOGpO4
