Author Topic: 500 550  (Read 7579 times)
Re: 500 550
« Reply #15 on: April 18, 2020, 07:33:02 PM »
So your engine is a CB500 K1
And your frame a CB550 F3 (sorry, I typed K4 previously)
The E and the F after the numbers just mean Engine and Frame.
« Last Edit: April 18, 2020, 07:39:16 PM by Nurse Julie »
Offline simonc
Re: 500 550
« Reply #16 on: April 18, 2020, 07:39:32 PM »
thanks for that info much appreciated :)
one job leads to another
cb72 1964
cb550f1 1976
cb550f1 1976
cb550 1977 with cb 500k engine
Re: 500 550
« Reply #17 on: April 18, 2020, 07:40:58 PM »
No problem, at least now you know for sure which models to order parts for both the frame and engine.
Re: 500 550
« Reply #18 on: April 18, 2020, 08:07:44 PM »
I should have added for anyone else that may look at this thread in the future, these engine and frame numbers relate to USA models ONLY. They have no bearing whatsoever with original UK model bikes as we have totally different models with totally different engine and frame numbers.
Offline matthewmosse
Re: 500 550
« Reply #19 on: April 18, 2020, 09:45:19 PM »
I have swapped and changed cb500 and 550 motors about between bikes with relative impunity regards electricals. No issues I can recall. Carbs can be a pitfall to swap about if you dont like jetting but that's part of living with a bitsa bike, seems restoration to original has similar issues.
Offline simonc
Re: 500 550
« Reply #20 on: April 18, 2020, 10:25:18 PM »
Cheers I have already stripped cleaned re jetted bigger set float heights. will decide later on final jetting new exhaust req
no real plan with this one. resprayed tank as a change from mechanical work, also restoring cb 72 super hawk so plenty to do ;)
cb72 1964
cb550f1 1976
cb550f1 1976
