Author Topic: CB550 Tappet Adjustment Question  (Read 5721 times)
Offline SPR
  • 1972 500/4 K1
« on: April 22, 2020, 08:50:11 AM »
Morning
1978 CB550K
So decided to check adjust the tappets but wanted to double check I've understood the info before I start
Been watching this YouTube video https://www.youtube.com/watch?v=u4QcrLbpmqk&list=FLftoUhSxu95e2Wa0_Q1jpnA&index=38&t=0s
So set the timing to 1.4 - see pic below ... have I got this correct ... is the T in the right place or does the mark left of the T need to be in the middle of the mark above it ?
Depending on where in the revolution I am I've got either #1 or #4 tappets loose - both exhaust and inlet
Am I good to go :)
Thanks Simon
Re: CB550 Tappet Adjustment Question
« Reply #1 on: April 22, 2020, 09:01:18 AM »
You can't become a expert in 4 minutes by watching a youtube vid  ;D
Line the T mark to 1-4 and set the appropriate tappets and then rotate the crank 360 to the same T mark 1-4 to do the other 4. Forget about the 2-3 mark  ;)
Offline SPR
  • 1972 500/4 K1
« Reply #2 on: April 22, 2020, 09:06:43 AM »
What's confusing me is that the manual seems to say when at 1-4 so certin tappets as below whereas the youtube vid says the opposite .... I'm a bit of a visual learner but like to check everything :)
So are you saying when at 1-4 I do as below ....
Sorry if I'm sounding dim
« Reply #3 on: April 22, 2020, 09:12:39 AM »
At T 1-4 it will be the O or X on the chart. If it is O and you want X turn the crank 360 degrees and at T 1-4 again to set the other 4  ;)
The manual is wrong, On the chart the in let is the exhaust and the exhaust is the inlet
« Last Edit: April 22, 2020, 09:15:57 AM by Trigger »
Offline SPR
  • 1972 500/4 K1
« Reply #4 on: April 22, 2020, 09:23:55 AM »
Many thanks !!!
« Reply #5 on: April 22, 2020, 09:42:21 AM »
Many thanks !!!
Like this >>>
Offline SPR
  • 1972 500/4 K1
« Reply #6 on: April 22, 2020, 09:48:02 AM »
Many thanks !!!
Brilliant thank you ... all checked and TBH only adjusted 3 slightly
Thanks again
Simon
Like this >>>
(Attachment Link)
« Reply #7 on: April 22, 2020, 09:52:31 AM »
Its far easier to understand if you ignore that chart and when set on T (which is a bit more clockwise on your pic) look at 1 & 4, one set will be loose the other tight so adjust the loose ones, rotate crank 360 deg (1 turn) and adjust the other set. Same for 2 & 3.
DO NOT turn the crank with a spanner on either the big nut or small nut at the points end
Offline SPR
  • 1972 500/4 K1
« Reply #8 on: April 22, 2020, 09:54:15 AM »
Many thanks ... hopefully won't have to redo for a little while ...I did think I needed to be a fraction more clockwise
Offline bobv7
« Reply #9 on: April 22, 2020, 10:20:14 AM »
Then all you need is a really skinny feeler gauge to get in the holes! I'm still trying to find one.
« Reply #10 on: April 22, 2020, 11:08:17 AM »
You just use standard feeler gauges and bend the ends  ;)
Offline SPR
  • 1972 500/4 K1
« Reply #11 on: April 22, 2020, 11:17:37 AM »
Thats what I did :)
Online deltarider
« Reply #12 on: April 22, 2020, 11:29:13 AM »
When you do it as Bryanj suggests - cylinder for cylinder - (I have made it a habbit since long), bonus is the marks do not have to align so precise as when you do it by Honda's scheme. My advice: forget about that scheme. Too much risk for us amateurs to make an error.
Offline SPR
  • 1972 500/4 K1
« Reply #13 on: April 22, 2020, 11:36:53 AM »
Noted - thanks :)
Offline Safo
« Reply #14 on: April 24, 2020, 02:38:54 PM »
Just about to do the same, but I would have gone the the long way round and used 2-3 ,made a note of triggers diagram.
